Part Number: PCM1681
Dear team
There is a good news that we design in PCM1681 in customer's new project.
Could you help to review the schematic?
Many thanks
Denny
Dear team
Many thanks
Denny
Hello, I will take a look at the schematics and let you know.
Arash
Hello, i did not see any issue with the schematic. You might want to consider adding LP filter to output.
Arash
Hi Loloee
For low pass filter, what value of cross frequency, could you recommend to design LP filter?
Many thanks
Denny
Well, you want to limit out of band noise or unwanted signals . So for audio for example you don't want anything above 20k.
Arash
Hello Loloee ,
Could you please help me to review the LP filter ?
Thank you.
Warm Regards
Edison
Hello, I don't know the reason why you are adding the 22uF cap in series with the 10uF.
Also I assume you added the 47k resistor to help to discharge the caps. I don't have any other comment .
Arash
Hello Loloee ,
Thanks for your reply.
So do you suggest me to remove 22uF in current schematic ?
/Edison
You already have a 10uF cap there, I assume you copied the filter from somewhere and thus brought the 22u with it. I would remove the 22uF.
Arash
