Hi team,
As the title, could you kindly tell me which audio amp can be recommend to customer?
BR
Jiawei
Hello Jiawei,
You didn't mention package because that matters.
This is in stock, and is an upgrade device
Hello Ronald,
Thanks for your reply! Since it's a developing project, package doesn't matter.
OPA1612A seems to be expensive, do we have another solution? Can we remove the noise at the start moment of motorcycle? Thanks!
BR
Jiawei
Hello Jiawei,
Here is a cookbook design that uses Single-ended input to differential output circuit using a dual channel op amp. Therefore looking at a audio op amps that are automotive grade, the following parametric table is left:
Ron suggested the OPA1612-Q1 as that is the only dual channel automotive op amp that is in stock:
All the best,
Carolina
