Hi all,
Could you please tell me the optimal audio amp which meets the below requirements?
1. Output power: 1W / 8-ohm, Single-end output
2. Bi polar output (if possible)
2. Supply voltage: less than DC 8V
3. Analog input
4. Ta: -20 to +70 deg C
Thanks in advance.
Toshi
Hi Toshi
The TPA2001D1 meets the requirements. You could use the TPA2005D1 or TPA2006D1 too. But they have an output power a little bit higher than 1W. I recommend you to take a look these devices.
Please let me know if you have more questions.
Best regards
José L. Figueroa
Audio Applications Engineer | A-Team
Low Power Audio and Actuators
Hi Figueroa-san,
Thanks for your response.
My customer's requirement is a single-end output because of their application.
So that I think your recommended ICs do not meet the 1W output.
If the power supply is grater than 8V, what is the recommendation?
Thanks and regards,
Toshi
