Part Number: TAS5751M
I have a problem similar to https://e2e.ti.com/support/audio-group/audio/f/audio-forum/647181/tas5751m-pwm-output-not-changing-between-ad-and-bd-modulation---no-audio-output/2379818#2379818, i.e. all the input signals and configuration seems to be correct, but the output signal does not contain any audio information, just the PWM signal.
Unfortunately, the solution (fix the soldering) does not apply, as all the soldering have been checked and are OK.
What could be the reason for the TAS5751M not to generate any output audio signal?
Thanks in advance for your help,
Kind regards,
