Part Number: TLV320AIC3262
Other Parts Discussed in Thread: ADS7828, PCM3168A, TMP108, TAS2562, TAS5086, TCA8418, LM3533, TPS65910, TPIC2810, LM3639, LM95241, TS3A227E, TPS65218, TPS65010, CDCE925, PCM1681, LM77, TPS65217, INA3221, LP3943, LM73, LM92, ADC128D818, TMP102, TMP401, TPD12S015, LM63, LM8333, CDCE706, PCM3060, BQ24257, BQ24735, TMP513, LP8727, PCM1789, AMC6821, TCA6416, LM93, LM90, BQ25980, INA209, TMP421, LM83, LM3630A, TWL6040, LM80, LM87, TAS6424, LM95245, BQ25890, SN65DSI86, LM95234, TMP103, TPA6130A2, TPS65090, TFP410, TAS2764, TPS65086, TAS2770, TAS2552, TPS65912
I have downloaded linux driver for aic3262 from /cfs-file/__key/communityserver-discussions-components-files/6/3262_2D00_E2E.zip and integrated the same into my kernel.
I got this driver from below e2e thread,
If i will go with this https://www.ti.com/tool/TLV320AIC32XX-DRIVERS Linux drivers then i don't have all the files available here for Linux driver integration, please tell me where are other files are located ?
I also have mkcfw tool to generate "tlv320aic3262_fw_v1.bin" which is requested by Linux driver.
I am using Linux kernel version - 5.10.41
my kernel config
# # Automatically generated file; DO NOT EDIT. # Linux/riscv 5.10.41 Kernel Configuration # CONFIG_CC_VERSION_TEXT="riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.24.0) 8.3.0" CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=80300 CONFIG_LD_VERSION=232000000 CONFIG_CLANG_VERSION=0 CONFIG_LLD_VERSION=0 CONFIG_CC_CAN_LINK=y CONFIG_CC_CAN_LINK_STATIC=y CONFIG_CC_HAS_ASM_GOTO=y CONFIG_CC_HAS_ASM_INLINE=y CONFIG_IRQ_WORK=y CONFIG_THREAD_INFO_IN_TASK=y # # General setup # CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="-nb2" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_BUILD_SALT="" CONFIG_DEFAULT_INIT="" CONFIG_DEFAULT_HOSTNAME="nb2-pearl" CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y # CONFIG_POSIX_MQUEUE is not set # CONFIG_WATCH_QUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_SHOW=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_HANDLE_DOMAIN_IRQ=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set # end of IRQ subsystem CONFIG_GENERIC_IRQ_MULTI_HANDLER=y CONFIG_ARCH_CLOCKSOURCE_INIT=y CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ is not set CONFIG_HIGH_RES_TIMERS=y # end of Timers subsystem CONFIG_PREEMPT_NONE=y # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # CONFIG_PSI is not set # end of CPU/Task time and stats accounting # # RCU Subsystem # CONFIG_TINY_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TINY_SRCU=y CONFIG_TASKS_RCU_GENERIC=y CONFIG_TASKS_TRACE_RCU=y # end of RCU Subsystem CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_IKHEADERS is not set CONFIG_LOG_BUF_SHIFT=17 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 CONFIG_GENERIC_SCHED_CLOCK=y # # Scheduler features # # end of Scheduler features CONFIG_CC_HAS_INT128=y CONFIG_ARCH_SUPPORTS_INT128=y CONFIG_CGROUPS=y # CONFIG_MEMCG is not set # CONFIG_BLK_CGROUP is not set CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y CONFIG_CFS_BANDWIDTH=y # CONFIG_RT_GROUP_SCHED is not set # CONFIG_CGROUP_PIDS is not set # CONFIG_CGROUP_RDMA is not set # CONFIG_CGROUP_FREEZER is not set # CONFIG_CGROUP_DEVICE is not set # CONFIG_CGROUP_CPUACCT is not set CONFIG_CGROUP_BPF=y # CONFIG_CGROUP_DEBUG is not set CONFIG_SOCK_CGROUP_DATA=y CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_IPC_NS=y CONFIG_USER_NS=y CONFIG_PID_NS=y CONFIG_NET_NS=y CONFIG_CHECKPOINT_RESTORE=y # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="core-image-tiny-initramfs-nb2-20220413111759.rootfs.cpio.gz" CONFIG_INITRAMFS_ROOT_UID=0 CONFIG_INITRAMFS_ROOT_GID=0 CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_RD_ZSTD=y CONFIG_INITRAMFS_COMPRESSION_GZIP=y # CONFIG_INITRAMFS_COMPRESSION_BZIP2 is not set # CONFIG_INITRAMFS_COMPRESSION_LZMA is not set # CONFIG_INITRAMFS_COMPRESSION_XZ is not set # CONFIG_INITRAMFS_COMPRESSION_LZO is not set # CONFIG_INITRAMFS_COMPRESSION_LZ4 is not set # CONFIG_INITRAMFS_COMPRESSION_ZSTD is not set # CONFIG_INITRAMFS_COMPRESSION_NONE is not set # CONFIG_BOOT_CONFIG is not set CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_SYSCTL_EXCEPTION_TRACE=y CONFIG_BPF=y CONFIG_EXPERT=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set # CONFIG_SYSFS_SYSCALL is not set CONFIG_FHANDLE=y CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_HAVE_FUTEX_CMPXCHG=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_BPF_SYSCALL=y # CONFIG_BPF_PRELOAD is not set # CONFIG_USERFAULTFD is not set CONFIG_KCMP=y # CONFIG_EMBEDDED is not set CONFIG_HAVE_PERF_EVENTS=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # # CONFIG_PERF_EVENTS is not set # end of Kernel Performance Events And Counters CONFIG_VM_EVENT_COUNTERS=y CONFIG_SLUB_DEBUG=y CONFIG_COMPAT_BRK=y # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set # CONFIG_PROFILING is not set # end of General setup CONFIG_64BIT=y CONFIG_RISCV=y CONFIG_ARCH_MMAP_RND_BITS_MIN=18 CONFIG_ARCH_MMAP_RND_BITS_MAX=24 CONFIG_RISCV_SBI=y CONFIG_MMU=y CONFIG_ZONE_DMA=y CONFIG_VA_BITS=39 CONFIG_PA_BITS=56 CONFIG_PAGE_OFFSET=0xffffffe000000000 CONFIG_ARCH_FLATMEM_ENABLE=y CONFIG_ARCH_SPARSEMEM_ENABLE=y CONFIG_ARCH_SELECT_MEMORY_MODEL=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y CONFIG_SYS_SUPPORTS_HUGETLBFS=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_GENERIC_BUG=y CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_GENERIC_CSUM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_PGTABLE_LEVELS=3 CONFIG_LOCKDEP_SUPPORT=y # # SoC selection # CONFIG_SOC_SIFIVE=y # CONFIG_SOC_VIRT is not set CONFIG_SOC_SIFIVE_NB2=y # end of SoC selection # # Platform type # # CONFIG_ARCH_RV32I is not set CONFIG_ARCH_RV64I=y # CONFIG_CMODEL_MEDLOW is not set CONFIG_CMODEL_MEDANY=y CONFIG_MODULE_SECTIONS=y CONFIG_MAXPHYSMEM_128GB=y # CONFIG_SMP is not set CONFIG_TUNE_GENERIC=y CONFIG_RISCV_ISA_C=y CONFIG_FPU=y # end of Platform type # # Kernel features # # CONFIG_HZ_100 is not set CONFIG_HZ_250=y # CONFIG_HZ_300 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=250 CONFIG_SCHED_HRTICK=y CONFIG_RISCV_SBI_V01=y # end of Kernel features # # Boot options # CONFIG_CMDLINE="" CONFIG_EFI_STUB=y CONFIG_EFI=y # end of Boot options # # Power management options # # CONFIG_SUSPEND is not set # CONFIG_PM is not set # end of Power management options # # Firmware Drivers # # CONFIG_FIRMWARE_MEMMAP is not set # CONFIG_GOOGLE_FIRMWARE is not set # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_ESRT=y CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_GENERIC_STUB=y # CONFIG_EFI_BOOTLOADER_CONTROL is not set # CONFIG_EFI_CAPSULE_LOADER is not set # CONFIG_EFI_TEST is not set # CONFIG_RESET_ATTACK_MITIGATION is not set # CONFIG_EFI_DISABLE_PCI_DMA is not set # end of EFI (Extensible Firmware Interface) Support CONFIG_EFI_EARLYCON=y # # Tegra firmware driver # # end of Tegra firmware driver # end of Firmware Drivers # # General architecture-dependent options # # CONFIG_JUMP_LABEL is not set CONFIG_HAVE_64BIT_ALIGNED_ACCESS=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_ARCH_HAS_SET_DIRECT_MAP=y CONFIG_HAVE_ASM_MODVERSIONS=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_HAVE_ARCH_JUMP_LABEL_RELATIVE=y CONFIG_HAVE_ARCH_SECCOMP=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP=y CONFIG_SECCOMP_FILTER=y CONFIG_HAVE_STACKPROTECTOR=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_RELA=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_ARCH_MMAP_RND_BITS=18 CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y CONFIG_CLONE_BACKWARDS=y # CONFIG_COMPAT_32BIT_TIME is not set CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_USE_MEMREMAP_PROT=y # CONFIG_LOCK_EVENT_COUNTS is not set # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y # end of GCOV-based kernel profiling CONFIG_HAVE_GCC_PLUGINS=y # end of General architecture-dependent options CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set # CONFIG_MODULE_COMPRESS is not set # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set # CONFIG_UNUSED_SYMBOLS is not set # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_BLOCK=y CONFIG_BLK_SCSI_REQUEST=y CONFIG_BLK_DEV_BSG=y # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set # CONFIG_BLK_CMDLINE_PARSER is not set # CONFIG_BLK_WBT is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # CONFIG_BLK_INLINE_ENCRYPTION is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_EFI_PARTITION=y # end of Partition Types CONFIG_BLK_MQ_VIRTIO=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set # end of IO Schedulers CONFIG_ASN1=y CONFIG_INLINE_SPIN_UNLOCK_IRQ=y CONFIG_INLINE_READ_UNLOCK=y CONFIG_INLINE_READ_UNLOCK_IRQ=y CONFIG_INLINE_WRITE_UNLOCK=y CONFIG_INLINE_WRITE_UNLOCK_IRQ=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_ARCH_HAS_MMIOWB=y # # Executable file formats # CONFIG_BINFMT_ELF=y CONFIG_ELFCORE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y CONFIG_ARCH_HAS_BINFMT_FLAT=y # CONFIG_BINFMT_FLAT is not set # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # end of Executable file formats # # Memory Management options # CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y # CONFIG_SPARSEMEM_MANUAL is not set CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_MEMORY_BALLOON=y CONFIG_BALLOON_COMPACTION=y CONFIG_COMPACTION=y CONFIG_PAGE_REPORTING=y CONFIG_MIGRATION=y CONFIG_PHYS_ADDR_T_64BIT=y CONFIG_BOUNCE=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_NEED_PER_CPU_KM=y # CONFIG_CLEANCACHE is not set # CONFIG_FRONTSWAP is not set # CONFIG_CMA is not set # CONFIG_ZPOOL is not set # CONFIG_ZBUD is not set # CONFIG_ZSMALLOC is not set CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_BENCHMARK is not set CONFIG_ARCH_HAS_PTE_SPECIAL=y # end of Memory Management options CONFIG_NET=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y CONFIG_UNIX_SCM=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set # CONFIG_XFRM_USER is not set # CONFIG_NET_KEY is not set # CONFIG_XDP_SOCKETS is not set CONFIG_INET=y # CONFIG_IP_MULTICAST is not set # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set # CONFIG_NET_FOU is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=y CONFIG_IPV6_ROUTER_PREF=y # CONFIG_IPV6_ROUTE_INFO is not set CONFIG_IPV6_OPTIMISTIC_DAD=y # CONFIG_INET6_AH is not set # CONFIG_INET6_ESP is not set # CONFIG_INET6_IPCOMP is not set # CONFIG_IPV6_MIP6 is not set CONFIG_INET6_TUNNEL=y # CONFIG_IPV6_VTI is not set # CONFIG_IPV6_SIT is not set CONFIG_IPV6_TUNNEL=y CONFIG_IPV6_MULTIPLE_TABLES=y # CONFIG_IPV6_SUBTREES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_IPV6_RPL_LWTUNNEL is not set # CONFIG_MPTCP is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set CONFIG_NETLINK_DIAG=y # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set # CONFIG_HSR is not set # CONFIG_NET_SWITCHDEV is not set # CONFIG_NET_L3_MASTER_DEV is not set # CONFIG_QRTR is not set # CONFIG_NET_NCSI is not set # CONFIG_CGROUP_NET_PRIO is not set # CONFIG_CGROUP_NET_CLASSID is not set CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_JIT is not set # CONFIG_BPF_STREAM_PARSER is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # end of Network testing # end of Networking options # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set CONFIG_FIB_RULES=y CONFIG_WIRELESS=y # CONFIG_CFG80211 is not set # # CFG80211 needs to be enabled for MAC80211 # CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y # CONFIG_FAILOVER is not set CONFIG_ETHTOOL_NETLINK=y CONFIG_HAVE_EBPF_JIT=y # # Device Drivers # CONFIG_HAVE_PCI=y # CONFIG_PCI is not set # CONFIG_PCCARD is not set # # Generic Driver Options # CONFIG_UEVENT_HELPER=y CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="tlv320aic3262_fw_v1.bin" CONFIG_EXTRA_FIRMWARE_DIR="/india/proj_ssw/work/pragneshp/project/mkcfw_r6.10fix6_130516" # CONFIG_FW_LOADER_USER_HELPER is not set # CONFIG_FW_LOADER_COMPRESS is not set # end of Firmware loader CONFIG_ALLOW_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_MMIO=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set # end of Generic Driver Options # # Bus devices # # CONFIG_MHI_BUS is not set # end of Bus devices # CONFIG_CONNECTOR is not set # CONFIG_GNSS is not set # CONFIG_MTD is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_CRYPTOLOOP is not set # CONFIG_BLK_DEV_DRBD is not set CONFIG_BLK_DEV_NBD=y # CONFIG_BLK_DEV_RAM is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set CONFIG_VIRTIO_BLK=y # CONFIG_BLK_DEV_RBD is not set # # NVME Support # # CONFIG_NVME_FC is not set # end of NVME Support # # Misc devices # # CONFIG_AD525X_DPOT is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set CONFIG_SRAM=y # CONFIG_XILINX_SDFEC is not set # CONFIG_PVPANIC is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # end of EEPROM support # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # end of Texas Instruments shared transport line discipline # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # CONFIG_ECHO is not set # end of Misc devices # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_BLK_DEV_SR is not set CONFIG_CHR_DEV_SG=y CONFIG_CHR_DEV_SCH=y # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # end of SCSI Transports CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_UFSHCD is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_VIRTIO is not set # CONFIG_SCSI_DH is not set # end of SCSI device support # CONFIG_ATA is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set # CONFIG_NETDEVICES is not set # CONFIG_NVM is not set # # Input device support # CONFIG_INPUT=y # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_POLLDEV is not set # CONFIG_INPUT_SPARSEKMAP is not set # CONFIG_INPUT_MATRIXKMAP is not set # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_QT1050 is not set # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set # CONFIG_KEYBOARD_GPIO is not set # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_SAMSUNG is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set # CONFIG_INPUT_TOUCHSCREEN is not set # CONFIG_INPUT_MISC is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_GPIO_PS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # end of Hardware I/O ports # end of Input device support # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=256 CONFIG_LDISC_AUTOLOAD=y # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y # CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set CONFIG_SERIAL_8250_16550A_VARIANTS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_NR_UARTS=6 CONFIG_SERIAL_8250_RUNTIME_UARTS=6 # CONFIG_SERIAL_8250_EXTENDED is not set # CONFIG_SERIAL_8250_ASPEED_VUART is not set CONFIG_SERIAL_8250_DWLIB=y CONFIG_SERIAL_8250_DW=y # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # CONFIG_SERIAL_EARLYCON_RISCV_SBI=y # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y CONFIG_SERIAL_SIFIVE=y CONFIG_SERIAL_SIFIVE_CONSOLE=y # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_FSL_LPUART is not set # CONFIG_SERIAL_FSL_LINFLEXUART is not set # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_SPRD is not set # end of Serial drivers CONFIG_SERIAL_MCTRL_GPIO=y # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_NULL_TTY is not set # CONFIG_TRACE_SINK is not set CONFIG_HVC_DRIVER=y CONFIG_HVC_RISCV_SBI=y # CONFIG_SERIAL_DEV_BUS is not set # CONFIG_TTY_PRINTK is not set CONFIG_VIRTIO_CONSOLE=y # CONFIG_IPMI_HANDLER is not set CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_BA431 is not set CONFIG_HW_RANDOM_VIRTIO=y CONFIG_HW_RANDOM_SIFIVE=y # CONFIG_HW_RANDOM_CCTRNG is not set # CONFIG_HW_RANDOM_XIPHERA is not set CONFIG_DEVMEM=y # CONFIG_DEVKMEM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set # CONFIG_XILLYBUS is not set # end of Character devices # CONFIG_RANDOM_TRUST_BOOTLOADER is not set # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y # CONFIG_I2C_COMPAT is not set CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set CONFIG_I2C_DESIGNWARE_CORE=y # CONFIG_I2C_DESIGNWARE_SLAVE is not set CONFIG_I2C_DESIGNWARE_PLATFORM=y # CONFIG_I2C_EMEV2 is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_TAOS_EVM is not set # # Other I2C/SMBus bus drivers # # end of I2C Hardware Bus support # CONFIG_I2C_STUB is not set # CONFIG_I2C_SLAVE is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # end of I2C support # CONFIG_I3C is not set # CONFIG_SPI is not set # CONFIG_SPMI is not set # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set # CONFIG_PTP_1588_CLOCK_IDTCM is not set # end of PTP clock support CONFIG_PINCTRL=y CONFIG_PINMUX=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_MCP23S08 is not set CONFIG_PINCTRL_NB2=y # CONFIG_PINCTRL_SINGLE is not set # CONFIG_PINCTRL_SX150X is not set # CONFIG_PINCTRL_STMFX is not set # CONFIG_PINCTRL_OCELOT is not set # # Renesas pinctrl drivers # # end of Renesas pinctrl drivers CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y CONFIG_GPIO_CDEV=y CONFIG_GPIO_CDEV_V1=y CONFIG_GPIO_GENERIC=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_CADENCE is not set CONFIG_GPIO_DWAPB=y # CONFIG_GPIO_FTGPIO010 is not set # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_LOGICVC is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_SAMA5D2_PIOBU is not set # CONFIG_GPIO_SIFIVE is not set # CONFIG_GPIO_SYSCON is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_AMD_FCH is not set # end of Memory mapped GPIO drivers # # I2C GPIO expanders # # CONFIG_GPIO_ADP5588 is not set # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCA9570 is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_TPIC2810 is not set # end of I2C GPIO expanders # # MFD GPIO expanders # # end of MFD GPIO expanders # CONFIG_GPIO_AGGREGATOR is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_W1 is not set # CONFIG_POWER_RESET is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set CONFIG_POWER_SUPPLY_HWMON=y # CONFIG_PDA_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_CHARGER_ADP5061 is not set # CONFIG_BATTERY_CW2015 is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SBS is not set # CONFIG_CHARGER_SBS is not set # CONFIG_BATTERY_BQ27XXX is not set # CONFIG_BATTERY_MAX17040 is not set # CONFIG_BATTERY_MAX17042 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_LT3651 is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ2515X is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_BQ25980 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_CHARGER_RT9455 is not set # CONFIG_CHARGER_BD99954 is not set CONFIG_HWMON=y # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1021 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM1177 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_AS370 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_AXI_FAN_CONTROL is not set # CONFIG_SENSORS_ASPEED is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_CORSAIR_CPRO is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_FTSTEUTATES is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set # CONFIG_SENSORS_GPIO_FAN is not set # CONFIG_SENSORS_HIH6130 is not set # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_JC42 is not set # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2947_I2C is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31730 is not set # CONFIG_SENSORS_MAX6621 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6642 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_TC654 is not set # CONFIG_SENSORS_MR75203 is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM73 is not set # CONFIG_SENSORS_LM75 is not set # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set # CONFIG_SENSORS_LM90 is not set # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set # CONFIG_SENSORS_LM95245 is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set # CONFIG_SENSORS_NTC_THERMISTOR is not set # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_NPCM7XX is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set # CONFIG_SENSORS_PWM_FAN is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_STTS751 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set # CONFIG_SENSORS_INA2XX is not set # CONFIG_SENSORS_INA3221 is not set # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set # CONFIG_SENSORS_TMP102 is not set # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP108 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_TMP513 is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_W83773G is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set # CONFIG_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y CONFIG_WATCHDOG_OPEN_TIMEOUT=0 CONFIG_WATCHDOG_SYSFS=y # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set CONFIG_DW_WATCHDOG=y # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_MEN_A21_WDT is not set CONFIG_SSB_POSSIBLE=y # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # CONFIG_BCMA is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set # CONFIG_MFD_BD9571MWV is not set # CONFIG_MFD_AXP20X_I2C is not set # CONFIG_MFD_MADERA is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_GATEWORKS_GSC is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_MP2629 is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_MFD_IQS62X is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77650 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_MT6360 is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_MENF21BMC is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y # CONFIG_MFD_TI_AM335X_TSCADC is not set # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set # CONFIG_MFD_TPS65218 is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS80031 is not set # CONFIG_TWL4030_CORE is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_ROHM_BD718XX is not set # CONFIG_MFD_ROHM_BD70528 is not set # CONFIG_MFD_ROHM_BD71828 is not set # CONFIG_MFD_STPMIC1 is not set # CONFIG_MFD_STMFX is not set # end of Multifunction device drivers # CONFIG_REGULATOR is not set # CONFIG_RC_CORE is not set # CONFIG_MEDIA_CEC_SUPPORT is not set # CONFIG_MEDIA_SUPPORT is not set # # Graphics support # CONFIG_DRM=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DEBUG_MM is not set # CONFIG_DRM_DEBUG_SELFTEST is not set CONFIG_DRM_KMS_HELPER=y CONFIG_DRM_KMS_FB_HELPER=y # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set CONFIG_DRM_FBDEV_EMULATION=y CONFIG_DRM_FBDEV_OVERALLOC=100 # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set # CONFIG_DRM_DP_CEC is not set CONFIG_DRM_GEM_CMA_HELPER=y CONFIG_DRM_KMS_CMA_HELPER=y # # I2C encoder or helper chips # # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set # CONFIG_DRM_I2C_NXP_TDA998X is not set # CONFIG_DRM_I2C_NXP_TDA9950 is not set # end of I2C encoder or helper chips # # ARM devices # # CONFIG_DRM_KOMEDA is not set # end of ARM devices # CONFIG_DRM_VGEM is not set # CONFIG_DRM_VKMS is not set # CONFIG_DRM_RCAR_DW_HDMI is not set # CONFIG_DRM_RCAR_LVDS is not set # CONFIG_DRM_VIRTIO_GPU is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_ARM_VERSATILE is not set CONFIG_DRM_PANEL_LVDS=y CONFIG_DRM_PANEL_SIMPLE=y # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set # end of Display Panels CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_CDNS_DSI is not set # CONFIG_DRM_CHRONTEL_CH7033 is not set # CONFIG_DRM_DISPLAY_CONNECTOR is not set # CONFIG_DRM_LONTIUM_LT9611 is not set # CONFIG_DRM_LVDS_CODEC is not set # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set # CONFIG_DRM_NWL_MIPI_DSI is not set # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set # CONFIG_DRM_PARADE_PS8640 is not set # CONFIG_DRM_SIL_SII8620 is not set # CONFIG_DRM_SII902X is not set # CONFIG_DRM_SII9234 is not set # CONFIG_DRM_SIMPLE_BRIDGE is not set # CONFIG_DRM_THINE_THC63LVD1024 is not set # CONFIG_DRM_TOSHIBA_TC358762 is not set # CONFIG_DRM_TOSHIBA_TC358764 is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TOSHIBA_TC358768 is not set # CONFIG_DRM_TOSHIBA_TC358775 is not set # CONFIG_DRM_TI_TFP410 is not set # CONFIG_DRM_TI_SN65DSI86 is not set # CONFIG_DRM_TI_TPD12S015 is not set # CONFIG_DRM_ANALOGIX_ANX6345 is not set # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_I2C_ADV7511 is not set # CONFIG_DRM_CDNS_MHDP8546 is not set # end of Display Interface Bridges # # Pearl/NB2 Display Driver # CONFIG_DRM_NB2=y CONFIG_DRM_NB2_LVDS=y # CONFIG_DRM_NB2_DW_MIPI_DSI is not set # end of Pearl/NB2 Display Driver # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_MXSFB is not set # CONFIG_DRM_LEGACY is not set CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y # # Frame buffer Devices # CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y CONFIG_FB=y CONFIG_FIRMWARE_EDID=y CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y CONFIG_FB_SYS_FILLRECT=y CONFIG_FB_SYS_COPYAREA=y CONFIG_FB_SYS_IMAGEBLIT=y CONFIG_FB_FOREIGN_ENDIAN=y CONFIG_FB_BOTH_ENDIAN=y # CONFIG_FB_BIG_ENDIAN is not set # CONFIG_FB_LITTLE_ENDIAN is not set CONFIG_FB_SYS_FOPS=y CONFIG_FB_DEFERRED_IO=y # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_EFI is not set # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_SIMPLE is not set # CONFIG_FB_SSD1307 is not set # end of Frame buffer Devices # # Backlight & LCD device support # CONFIG_LCD_CLASS_DEVICE=y # CONFIG_LCD_PLATFORM is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y # CONFIG_BACKLIGHT_KTD253 is not set CONFIG_BACKLIGHT_PWM=y # CONFIG_BACKLIGHT_QCOM_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3630A is not set # CONFIG_BACKLIGHT_LM3639 is not set # CONFIG_BACKLIGHT_LP855X is not set # CONFIG_BACKLIGHT_GPIO is not set # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set # CONFIG_BACKLIGHT_ARCXCNN is not set # end of Backlight & LCD device support CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_VGA_CONSOLE=y CONFIG_DUMMY_CONSOLE=y CONFIG_DUMMY_CONSOLE_COLUMNS=80 CONFIG_DUMMY_CONSOLE_ROWS=25 CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER=y # end of Console display driver support CONFIG_LOGO=y CONFIG_LOGO_LINUX_MONO=y CONFIG_LOGO_LINUX_VGA16=y CONFIG_LOGO_LINUX_CLUT224=y # end of Graphics support CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_SEQUENCER is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set # # HD-Audio # # end of HD-Audio CONFIG_SND_HDA_PREALLOC_SIZE=64 CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set CONFIG_SND_CADENCE_I2S=y # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set # CONFIG_SND_SOC_FSL_SAI is not set # CONFIG_SND_SOC_FSL_AUDMIX is not set # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_FSL_MICFIL is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # end of SoC Audio for Freescale CPUs # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set CONFIG_SND_SOC_NB2_PDM=y # CONFIG_SND_SOC_SOF_TOPLEVEL is not set # # STMicroelectronics STM32 SOC audio support # # end of STMicroelectronics STM32 SOC audio support # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set # CONFIG_ZX_TDM is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # AIC326X DRIVER # # # Texas Instruments aic326x device # CONFIG_SND_SOC_AIC326X=y # end of Texas Instruments aic326x device # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_ADAU7118_HW is not set # CONFIG_SND_SOC_ADAU7118_I2C is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_BD28623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS4234 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_CX2072X is not set # CONFIG_SND_SOC_DA7213 is not set CONFIG_SND_SOC_DMIC=y # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set # CONFIG_SND_SOC_MAX98357A is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set # CONFIG_SND_SOC_MAX98927 is not set # CONFIG_SND_SOC_MAX98373_I2C is not set # CONFIG_SND_SOC_MAX98390 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3168A_I2C is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_SGTL5000 is not set # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set # CONFIG_SND_SOC_SPDIF is not set # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS2562 is not set # CONFIG_SND_SOC_TAS2764 is not set # CONFIG_SND_SOC_TAS2770 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC31XX is not set # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set # CONFIG_SND_SOC_TLV320AIC3X is not set # CONFIG_SND_SOC_TLV320ADCX140 is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_UDA1334 is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8524 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731 is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8903 is not set # CONFIG_SND_SOC_WM8904 is not set # CONFIG_SND_SOC_WM8960 is not set # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set # CONFIG_SND_SOC_WM8978 is not set # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_ZX_AUD96P22 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_MT6660 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8822 is not set # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set # end of CODEC drivers CONFIG_SND_SIMPLE_CARD_UTILS=y CONFIG_SND_SIMPLE_CARD=y # CONFIG_SND_AUDIO_GRAPH_CARD is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_COUGAR is not set # CONFIG_HID_MACALLY is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_GLORIOUS is not set # CONFIG_HID_VIVALDI is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_VIEWSONIC is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_ITE is not set # CONFIG_HID_JABRA is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MALTRON is not set # CONFIG_HID_MAYFLASH is not set # CONFIG_HID_REDRAGON is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set # CONFIG_HID_MULTITOUCH is not set # CONFIG_HID_NTI is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEAM is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # end of Special HID drivers # # I2C HID support # # CONFIG_I2C_HID is not set # end of I2C HID support # end of HID support CONFIG_USB_OHCI_LITTLE_ENDIAN=y # CONFIG_USB_SUPPORT is not set # CONFIG_MMC is not set # CONFIG_MEMSTICK is not set # CONFIG_NEW_LEDS is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_SUPPORT=y # CONFIG_EDAC is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc1" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc1" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_ISL12026 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF85363 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV3028 is not set # CONFIG_RTC_DRV_RV3032 is not set # CONFIG_RTC_DRV_RV8803 is not set # CONFIG_RTC_DRV_SD3078 is not set # # SPI RTC drivers # CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # # Platform RTC drivers # CONFIG_RTC_DRV_DWAPB=y # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set # CONFIG_RTC_DRV_EFI is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set # CONFIG_RTC_DRV_R7301 is not set # # HID Sensor RTC drivers # CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set CONFIG_DW_AXI_DMAC=y # CONFIG_FSL_EDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_XILINX_ZYNQMP_DPDMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set # CONFIG_DW_DMAC is not set # CONFIG_SF_PDMA is not set # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set CONFIG_DMATEST=y CONFIG_DMA_ENGINE_RAID=y # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_UDMABUF is not set # CONFIG_DMABUF_MOVE_NOTIFY is not set # CONFIG_DMABUF_SELFTESTS is not set # CONFIG_DMABUF_HEAPS is not set # end of DMABUF options # CONFIG_AUXDISPLAY is not set CONFIG_UIO=y CONFIG_UIO_PDRV_GENIRQ=y CONFIG_UIO_DMEM_GENIRQ=y # CONFIG_UIO_PRUSS is not set # CONFIG_VFIO is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO=y CONFIG_VIRTIO_MENU=y CONFIG_VIRTIO_BALLOON=y CONFIG_VIRTIO_INPUT=y CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # CONFIG_VDPA is not set CONFIG_VHOST_MENU=y # CONFIG_VHOST_NET is not set # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set # # Microsoft Hyper-V guest support # # end of Microsoft Hyper-V guest support # CONFIG_GREYBUS is not set # CONFIG_STAGING is not set # CONFIG_GOLDFISH is not set CONFIG_HAVE_CLK=y CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # CONFIG_COMMON_CLK_MAX9485 is not set # CONFIG_COMMON_CLK_SI5341 is not set # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_COMMON_CLK_PWM is not set # CONFIG_COMMON_CLK_VC5 is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC=y CONFIG_CLK_SIFIVE=y CONFIG_CLK_SIFIVE_FU540_PRCI=y # CONFIG_HWSPINLOCK is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_RISCV_TIMER=y # CONFIG_MICROCHIP_PIT64B is not set # end of Clock Source drivers # CONFIG_MAILBOX is not set CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # # end of Generic IOMMU Pagetable Support # CONFIG_IOMMU_DEBUGFS is not set # # Remoteproc drivers # # CONFIG_REMOTEPROC is not set # end of Remoteproc drivers # # Rpmsg drivers # CONFIG_RPMSG=y CONFIG_RPMSG_CHAR=y CONFIG_RPMSG_VIRTIO=y # end of Rpmsg drivers # CONFIG_SOUNDWIRE is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # end of Amlogic SoC drivers # # Aspeed SoC drivers # # end of Aspeed SoC drivers # # Broadcom SoC drivers # # end of Broadcom SoC drivers # # NXP/Freescale QorIQ SoC drivers # # end of NXP/Freescale QorIQ SoC drivers # # i.MX SoC drivers # # end of i.MX SoC drivers # # Qualcomm SoC drivers # # end of Qualcomm SoC drivers CONFIG_SIFIVE_L2=y CONFIG_IPC_DRV_NB2=y # CONFIG_SOC_TI is not set # # Xilinx SoC drivers # # CONFIG_XILINX_VCU is not set # end of Xilinx SoC drivers # end of SOC (System On Chip) specific Drivers # CONFIG_PM_DEVFREQ is not set # CONFIG_EXTCON is not set # CONFIG_MEMORY is not set # CONFIG_IIO is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_DEBUG is not set # CONFIG_PWM_CADENCE is not set # CONFIG_PWM_FSL_FTM is not set # CONFIG_PWM_PCA9685 is not set # CONFIG_PWM_SIFIVE is not set # # IRQ chip support # CONFIG_IRQCHIP=y # CONFIG_AL_FIC is not set CONFIG_RISCV_INTC=y CONFIG_SIFIVE_PLIC=y # end of IRQ chip support # CONFIG_IPACK_BUS is not set CONFIG_RESET_CONTROLLER=y # CONFIG_RESET_BRCMSTB_RESCAL is not set # CONFIG_RESET_INTEL_GW is not set # CONFIG_RESET_TI_SYSCON is not set # # PHY Subsystem # # CONFIG_GENERIC_PHY is not set # CONFIG_BCM_KONA_USB2_PHY is not set # CONFIG_PHY_CADENCE_TORRENT is not set # CONFIG_PHY_CADENCE_DPHY is not set # CONFIG_PHY_CADENCE_SIERRA is not set # CONFIG_PHY_CADENCE_SALVO is not set # CONFIG_PHY_FSL_IMX8MQ_USB is not set # CONFIG_PHY_MIXEL_MIPI_DPHY is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_OCELOT_SERDES is not set # CONFIG_NB2_M31_USB2_PHY is not set # CONFIG_NB2_M31_USB3_PHY is not set # CONFIG_NB2_M31_MIPI_DPHY is not set # end of PHY Subsystem # CONFIG_POWERCAP is not set # CONFIG_MCB is not set CONFIG_RAS=y # # Android # # CONFIG_ANDROID is not set # end of Android # CONFIG_LIBNVDIMM is not set # CONFIG_DAX is not set CONFIG_NVMEM=y # CONFIG_NVMEM_SYSFS is not set # # HW tracing support # # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # end of HW tracing support # CONFIG_FPGA is not set # CONFIG_FSI is not set # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set # CONFIG_INTERCONNECT is not set # CONFIG_COUNTER is not set # end of Device Drivers # # File systems # # CONFIG_VALIDATE_FS_PARSER is not set CONFIG_FS_IOMAP=y # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set CONFIG_EXT4_FS=y # CONFIG_EXT4_USE_FOR_EXT2 is not set CONFIG_EXT4_FS_POSIX_ACL=y # CONFIG_EXT4_FS_SECURITY is not set # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set # CONFIG_FS_DAX is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y CONFIG_MANDATORY_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set # CONFIG_FS_VERITY is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set CONFIG_AUTOFS4_FS=y CONFIG_AUTOFS_FS=y # CONFIG_FUSE_FS is not set # CONFIG_OVERLAY_FS is not set # # Caches # # CONFIG_FSCACHE is not set # end of Caches # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # end of CD-ROM/DVD Filesystems # # DOS/FAT/EXFAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" CONFIG_FAT_DEFAULT_UTF8=y # CONFIG_EXFAT_FS is not set CONFIG_NTFS_FS=y # CONFIG_NTFS_DEBUG is not set CONFIG_NTFS_RW=y # end of DOS/FAT/EXFAT/NT Filesystems # # Pseudo filesystems # CONFIG_PROC_FS=y # CONFIG_PROC_KCORE is not set CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_PROC_CHILDREN=y CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y # CONFIG_TMPFS_INODE64 is not set # CONFIG_HUGETLBFS is not set CONFIG_MEMFD_CREATE=y CONFIG_ARCH_HAS_GIGANTIC_PAGE=y # CONFIG_CONFIGFS_FS is not set CONFIG_EFIVAR_FS=m # end of Pseudo filesystems CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_CRAMFS is not set # CONFIG_SQUASHFS is not set # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_PSTORE is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_EROFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=m CONFIG_NFS_V2=m CONFIG_NFS_V3=m CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=m # CONFIG_NFS_SWAP is not set CONFIG_NFS_V4_1=y # CONFIG_NFS_V4_2 is not set CONFIG_PNFS_FILE_LAYOUT=m CONFIG_PNFS_FLEXFILE_LAYOUT=m CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org" # CONFIG_NFS_V4_1_MIGRATION is not set # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y CONFIG_NFS_DISABLE_UDP_SUPPORT=y # CONFIG_NFSD is not set CONFIG_GRACE_PERIOD=m CONFIG_LOCKD=m CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=m CONFIG_NFS_COMMON=y CONFIG_SUNRPC=m CONFIG_SUNRPC_GSS=m CONFIG_SUNRPC_BACKCHANNEL=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y CONFIG_NLS_CODEPAGE_737=y CONFIG_NLS_CODEPAGE_775=y CONFIG_NLS_CODEPAGE_850=y CONFIG_NLS_CODEPAGE_852=y CONFIG_NLS_CODEPAGE_855=y CONFIG_NLS_CODEPAGE_857=y CONFIG_NLS_CODEPAGE_860=y CONFIG_NLS_CODEPAGE_861=y CONFIG_NLS_CODEPAGE_862=y CONFIG_NLS_CODEPAGE_863=y CONFIG_NLS_CODEPAGE_864=y CONFIG_NLS_CODEPAGE_865=y CONFIG_NLS_CODEPAGE_866=y CONFIG_NLS_CODEPAGE_869=y CONFIG_NLS_CODEPAGE_936=y CONFIG_NLS_CODEPAGE_950=y CONFIG_NLS_CODEPAGE_932=y CONFIG_NLS_CODEPAGE_949=y CONFIG_NLS_CODEPAGE_874=y CONFIG_NLS_ISO8859_8=y CONFIG_NLS_CODEPAGE_1250=y CONFIG_NLS_CODEPAGE_1251=y CONFIG_NLS_ASCII=y CONFIG_NLS_ISO8859_1=y CONFIG_NLS_ISO8859_2=y CONFIG_NLS_ISO8859_3=y CONFIG_NLS_ISO8859_4=y CONFIG_NLS_ISO8859_5=y CONFIG_NLS_ISO8859_6=y CONFIG_NLS_ISO8859_7=y CONFIG_NLS_ISO8859_9=y CONFIG_NLS_ISO8859_13=y CONFIG_NLS_ISO8859_14=y CONFIG_NLS_ISO8859_15=y CONFIG_NLS_KOI8_R=y CONFIG_NLS_KOI8_U=y CONFIG_NLS_MAC_ROMAN=y CONFIG_NLS_MAC_CELTIC=y CONFIG_NLS_MAC_CENTEURO=y CONFIG_NLS_MAC_CROATIAN=y CONFIG_NLS_MAC_CYRILLIC=y CONFIG_NLS_MAC_GAELIC=y CONFIG_NLS_MAC_GREEK=y CONFIG_NLS_MAC_ICELAND=y CONFIG_NLS_MAC_INUIT=y CONFIG_NLS_MAC_ROMANIAN=y CONFIG_NLS_MAC_TURKISH=y CONFIG_NLS_UTF8=y # CONFIG_UNICODE is not set CONFIG_IO_WQ=y # end of File systems # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_REQUEST_CACHE is not set # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity,bpf" # # Kernel hardening options # # # Memory initialization # CONFIG_INIT_STACK_NONE=y # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set # end of Memory initialization # end of Kernel hardening options # end of Security options CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_SKCIPHER=y CONFIG_CRYPTO_SKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y # CONFIG_CRYPTO_NULL is not set CONFIG_CRYPTO_NULL2=y # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set # CONFIG_CRYPTO_TEST is not set CONFIG_CRYPTO_ENGINE=y # # Public-key cryptography # CONFIG_CRYPTO_RSA=y # CONFIG_CRYPTO_DH is not set # CONFIG_CRYPTO_ECDH is not set # CONFIG_CRYPTO_ECRDSA is not set # CONFIG_CRYPTO_SM2 is not set # CONFIG_CRYPTO_CURVE25519 is not set # # Authenticated Encryption with Associated Data # # CONFIG_CRYPTO_CCM is not set # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set # CONFIG_CRYPTO_AEGIS128 is not set # CONFIG_CRYPTO_SEQIV is not set # CONFIG_CRYPTO_ECHAINIV is not set # # Block modes # # CONFIG_CRYPTO_CBC is not set # CONFIG_CRYPTO_CFB is not set # CONFIG_CRYPTO_CTR is not set # CONFIG_CRYPTO_CTS is not set # CONFIG_CRYPTO_ECB is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_ADIANTUM is not set # CONFIG_CRYPTO_ESSIV is not set # # Hash modes # # CONFIG_CRYPTO_CMAC is not set # CONFIG_CRYPTO_HMAC is not set # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_XXHASH is not set # CONFIG_CRYPTO_BLAKE2B is not set # CONFIG_CRYPTO_BLAKE2S is not set # CONFIG_CRYPTO_CRCT10DIF is not set # CONFIG_CRYPTO_GHASH is not set # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_MD4 is not set # CONFIG_CRYPTO_MD5 is not set # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set # CONFIG_CRYPTO_SHA1 is not set CONFIG_CRYPTO_SHA256=y # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_SM3 is not set # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # # CONFIG_CRYPTO_AES is not set # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_CHACHA20 is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_SM4 is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # # CONFIG_CRYPTO_DEFLATE is not set # CONFIG_CRYPTO_LZO is not set # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set # CONFIG_CRYPTO_ZSTD is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set # CONFIG_CRYPTO_DRBG_MENU is not set # CONFIG_CRYPTO_JITTERENTROPY is not set # CONFIG_CRYPTO_USER_API_HASH is not set # CONFIG_CRYPTO_USER_API_SKCIPHER is not set # CONFIG_CRYPTO_USER_API_RNG is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_HASH_INFO=y # # Crypto library routines # # CONFIG_CRYPTO_LIB_BLAKE2S is not set # CONFIG_CRYPTO_LIB_CHACHA is not set # CONFIG_CRYPTO_LIB_CURVE25519 is not set CONFIG_CRYPTO_LIB_POLY1305_RSIZE=1 # CONFIG_CRYPTO_LIB_POLY1305 is not set # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set CONFIG_CRYPTO_LIB_SHA256=y CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set # CONFIG_CRYPTO_DEV_SIFIVE_HCA is not set CONFIG_CRYPTO_DEV_VIRTIO=y # CONFIG_CRYPTO_DEV_SAFEXCEL is not set # CONFIG_CRYPTO_DEV_CCREE is not set # CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # # Certificates for signature checking # # CONFIG_SYSTEM_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # end of Certificates for signature checking # # Library routines # # CONFIG_PACKING is not set CONFIG_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y # CONFIG_CORDIC is not set # CONFIG_PRIME_NUMBERS is not set CONFIG_RATIONAL=y CONFIG_GENERIC_PCI_IOMAP=y # CONFIG_CRC_CCITT is not set CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set CONFIG_CRC_ITU_T=y CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC64 is not set # CONFIG_CRC4 is not set CONFIG_CRC7=y # CONFIG_LIBCRC32C is not set # CONFIG_CRC8 is not set CONFIG_XXHASH=y # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_ZSTD_DECOMPRESS=y CONFIG_XZ_DEC=y # CONFIG_XZ_DEC_X86 is not set # CONFIG_XZ_DEC_POWERPC is not set # CONFIG_XZ_DEC_IA64 is not set # CONFIG_XZ_DEC_ARM is not set # CONFIG_XZ_DEC_ARMTHUMB is not set # CONFIG_XZ_DEC_SPARC is not set # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_DECOMPRESS_ZSTD=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_ARCH_DMA_ADDR_T_64BIT=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_SWIOTLB=y # CONFIG_DMA_API_DEBUG is not set CONFIG_SGL_ALLOC=y CONFIG_DQL=y CONFIG_NLATTR=y CONFIG_CLZ_TAB=y # CONFIG_IRQ_POLL is not set CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_HAVE_GENERIC_VDSO=y CONFIG_GENERIC_GETTIMEOFDAY=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y CONFIG_SG_POOL=y CONFIG_SBITMAP=y # CONFIG_STRING_SELFTEST is not set # end of Library routines CONFIG_GENERIC_IOREMAP=y # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_DYNAMIC_DEBUG_CORE is not set CONFIG_SYMBOLIC_ERRNAME=y CONFIG_DEBUG_BUGVERBOSE=y # end of printk and dmesg options # # Compile-time checks and compiler options # CONFIG_DEBUG_INFO=y # CONFIG_DEBUG_INFO_REDUCED is not set # CONFIG_DEBUG_INFO_COMPRESSED is not set # CONFIG_DEBUG_INFO_SPLIT is not set # CONFIG_DEBUG_INFO_DWARF4 is not set # CONFIG_DEBUG_INFO_BTF is not set # CONFIG_GDB_SCRIPTS is not set CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=2048 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_HEADERS_INSTALL is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_32B is not set CONFIG_ARCH_WANT_FRAME_POINTERS=y CONFIG_FRAME_POINTER=y # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # end of Compile-time checks and compiler options # # Generic Kernel Debugging Instruments # CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_MAGIC_SYSRQ_SERIAL=y CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE="" CONFIG_DEBUG_FS=y CONFIG_DEBUG_FS_ALLOW_ALL=y # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set # CONFIG_DEBUG_FS_ALLOW_NONE is not set CONFIG_HAVE_ARCH_KGDB=y CONFIG_HAVE_ARCH_KGDB_QXFER_PKT=y # CONFIG_KGDB is not set # CONFIG_UBSAN is not set # end of Generic Kernel Debugging Instruments CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_RODATA_TEST is not set CONFIG_ARCH_HAS_DEBUG_WX=y # CONFIG_DEBUG_WX is not set CONFIG_GENERIC_PTDUMP=y # CONFIG_PTDUMP_DEBUGFS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_SLUB_STATS is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set CONFIG_SCHED_STACK_END_CHECK=y CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_VM_PGTABLE is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set CONFIG_HAVE_ARCH_KASAN=y CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y # CONFIG_KASAN is not set # end of Memory Debugging # CONFIG_DEBUG_SHIRQ is not set # # Debug Oops, Lockups and Hangs # # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 CONFIG_LOCKUP_DETECTOR=y CONFIG_SOFTLOCKUP_DETECTOR=y # CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0 CONFIG_DETECT_HUNG_TASK=y CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=120 # CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0 CONFIG_WQ_WATCHDOG=y # CONFIG_TEST_LOCKUP is not set # end of Debug Oops, Lockups and Hangs # # Scheduler Debugging # CONFIG_SCHED_DEBUG=y # CONFIG_SCHEDSTATS is not set # end of Scheduler Debugging # CONFIG_DEBUG_TIMEKEEPING is not set # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # CONFIG_SCF_TORTURE_TEST is not set # CONFIG_CSD_LOCK_WAIT_DEBUG is not set # end of Lock Debugging (spinlocks, mutexes, etc...) CONFIG_STACKTRACE=y # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set # # Debug kernel data structures # # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PLIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # end of Debug kernel data structures # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_SCALE_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_RCU_REF_SCALE_TEST is not set # CONFIG_RCU_TRACE is not set # CONFIG_RCU_EQS_DEBUG is not set # end of RCU Debugging # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # CONFIG_SAMPLES is not set # # riscv Debugging # # # Kernel Testing and Coverage # # CONFIG_KUNIT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y # CONFIG_KCOV is not set # CONFIG_RUNTIME_TESTING_MENU is not set CONFIG_MEMTEST=y # end of Kernel Testing and Coverage # end of Kernel hacking
my kernel dts
sound0: sound0 {
compatible = "simple-audio-card";
simple-audio-card,name = "tlv320aic3262-hifi";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
sound_master: simple-audio-card,cpu {
sound-dai = <&i2s0>;
//dai-tdm-slot-num = <2>;
simple-audio-card,codec {
sound-dai = <&tlv320aic3262>;
&i2c3 {
status = "okay";
tlv320aic3262: codec@18 {
compatible = "ti,aic3262";
reg = <0x18>;
#sound-dai-cells= <0>;
status = "okay";
i2s0: i2s0@300080000 {
#sound-dai-cells = <0>;
compatible = "cdns,cadence-i2s";
reg = <0x3 0x00080000 0x0 0x1000>;
interrupt-parent = <&plic0>;
interrupts = <76>;
dmas = <&dmac2 0 1>, <&dmac2 1 1>;
dma-names = "rx", "tx";
clock-names = "clk_i2s", "clk";
clocks = <&i2sclk>, <&i2sclk>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2s0_clk_grp0
&pinctrl_i2s0_lrclk_grp0
&pinctrl_i2s0_dout_grp0
&pinctrl_i2s0_din_grp0>;
status = "okay";
I have added few debug logs in aic3262, my kernel debug logs
U-Boot SPL 2020.07-rc3-00015-gcdbb212-dirty (Apr 18 2022 - 18:29:07 +0530)
Trying to boot from RAM
U-Boot 2020.07-rc3-00015-gcdbb212-dirty (Apr 18 2022 - 18:29:07 +0530)
CPU: rv64imafdc
Model: SiFive Pearl
DRAM: 1.8 GiB
In: serial@4F0009000
Out: serial@4F0009000
Err: serial@4F0009000
Hit any key to stop autoboot: 0
## Flattened Device Tree blob at 80f000000
Booting using the fdt blob at 0x80f000000
Using Device Tree in place at 000000080f000000, end 000000080f0102e5
Starting kernel ...
[ 0.000000] Linux version 5.10.41-nb2+ (pragneshp@osubuntu003) (riscv64-unknown-linux-gnu-gcc (crosstool-NG
1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1193 Mon Apr 18 18:19:00 IST 2022
[ 0.000000] OF: fdt: Ignoring memory range 0x800600000 - 0x800800000
[ 0.000000] efi: UEFI not found.
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000800800000-0x00000008705fffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000800800000-0x00000008475fcfff]
[ 0.000000] node 0: [mem 0x00000008475fd000-0x00000008494fffff]
[ 0.000000] node 0: [mem 0x0000000849500000-0x00000008495fffff]
[ 0.000000] node 0: [mem 0x0000000849600000-0x00000008585fffff]
[ 0.000000] node 0: [mem 0x0000000858600000-0x00000008705fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000800800000-0x00000008705fffff]
[ 0.000000] SBI specification v0.2 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x9
[ 0.000000] SBI v0.2 TIME extension detected
[ 0.000000] SBI v0.2 IPI extension detected
[ 0.000000] SBI v0.2 RFENCE extension detected
[ 0.000000] software IO TLB: mapped [mem 0x0000002800800000-0x0000002804800000] (64MB)
[ 0.000000] CPU with hartid=1 is not available
[ 0.000000] CPU with hartid=2 is not available
[ 0.000000] CPU with hartid=3 is not available
[ 0.000000] riscv: ISA extensions acdfim
[ 0.000000] riscv: ELF capabilities acdfim
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 451975
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 root=/dev/ram0 rw rdinit=/sbin/init
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Sorting __ex_table...
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1486304K/1832960K available (4508K kernel code, 4305K rwdata, 4096K rodata, 176K init, 2
90K bss, 346656K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] riscv-intc: 64 local interrupts mapped
[ 0.000000] riscv-intc: unable to find hart id for /cpus/cpu@1/interrupt-controller
[ 0.000000] riscv-intc: unable to find hart id for /cpus/cpu@2/interrupt-controller
[ 0.000000] riscv-intc: unable to find hart id for /cpus/cpu@3/interrupt-controller
[ 0.000000] plic: interrupt-controller@c000000: mapped 137 interrupts with 1 handlers for 2 contexts.
[ 0.000000] random: get_random_bytes called from start_kernel+0x31a/0x49e with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3
526361616960 ns
[ 0.000006] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
[ 0.000733] Console: colour dummy device 80x25
[ 0.001307] printk: console [tty1] enabled
[ 0.001380] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=40
00)
[ 0.001425] pid_max: default: 32768 minimum: 301
[ 0.001706] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001845] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.004487] EFI services will not be available.
[ 0.005242] devtmpfs: initialized
[ 0.017878] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.017947] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.018116] pinctrl core: initialized pinctrl subsystem
[ 0.018859] NET: Registered protocol family 16
[ 0.041075] fbcon: Taking over console
[ 0.041517] SCSI subsystem initialized
[ 0.041662] pps_core: LinuxPPS API ver. 1 registered
[ 0.041696] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.041773] PTP clock support registered
[ 0.042020] Advanced Linux Sound Architecture Driver Initialized.
[ 0.043167] clocksource: Switched to clocksource riscv_clocksource
[ 0.054925] NET: Registered protocol family 2
[ 0.055947] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.057691] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.057827] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.058327] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.058833] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.059446] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.059620] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.060016] NET: Registered protocol family 1
[ 2.018823] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[ 2.027727] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.028410] Key type asymmetric registered
[ 2.028453] Asymmetric key parser 'x509' registered
[ 2.028544] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 2.028589] io scheduler mq-deadline registered
[ 2.028615] io scheduler kyber registered
[ 2.033312] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
[ 2.034212] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
[ 2.034611] L2CACHE: No. of Banks in the cache: 4
[ 2.034646] L2CACHE: No. of ways per bank: 16
[ 2.034660] L2CACHE: Sets per bank: 256
[ 2.034674] L2CACHE: Bytes per cache block: 64
[ 2.034689] L2CACHE: Index of the largest way enabled: 2
[ 2.063308] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 2.064983] printk: console [ttyS0] disabled
[ 2.065072] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
[ 2.620317] printk: console [ttyS0] enabled
[ 2.626286] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for displa
y-subsystem.
[ 2.637257] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
[ 2.658006] loop: module loaded
[ 2.683412] SCSI Media Changer driver v0.25
[ 2.688037] i2c /dev entries driver
[ 2.694026] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
[ 2.711254] tlv320aic3262-codec 2-0018: TLV320AIC3262 revision G
[ 2.717423] tlv320aic3262-codec 2-0018: aic3xxx_device_init added mfd devices
[ 2.726349] NET: Registered protocol family 10
[ 2.731802] Segment Routing with IPv6
[ 2.736102] NET: Registered protocol family 17
[ 2.740653] Key type dns_resolver registered
[ 2.746586] aic3262_codec_probe enter
[ 2.746602] driver_init: Allocated Major Number: 245
[ 2.746602]
[ 2.756821] driver_init: Registered cfw driver
[ 2.761479] aic3262_codec_read enter
[ 2.762206] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
[ 2.771072] aic3262_codec_read exit
[ 2.771076] aic3262_codec_write enter
[ 2.774589] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
[ 2.783429] aic3262_codec_write exit
[ 2.823690] aic3262_codec_read enter
[ 2.827686] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
[ 2.836623] aic3262_codec_read exit
[ 2.836625] aic3262_codec_write enter
[ 2.840137] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
[ 2.849061] aic3262_codec_write exit
[ 2.849363] aic3262_codec_probe exit
[ 2.853083] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
AC_CLK] -> ASI1_BCLK Route)
[ 2.868905] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI1_BCLK Route
[ 2.878247] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI1_BCLK Route
[ 2.887597] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
-> [DAC_MOD_CLK] -> ASI1_BCLK Route)
[ 2.900588] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI1_BCLK Ro
ute
[ 2.910711] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI1_BCLK Ro
ute
[ 2.920834] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
DC_CLK] -> ASI1_BCLK Route)
[ 2.933041] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI1_BCLK Route
[ 2.942381] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI1_BCLK Route
[ 2.951721] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
-> [ADC_MOD_CLK] -> ASI1_BCLK Route)
[ 2.964709] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI1_BCLK Ro
ute
[ 2.974829] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI1_BCLK Ro
ute
[ 2.984956] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
AC_CLK] -> ASI2_BCLK Route)
[ 2.997164] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI2_BCLK Route
[ 3.006506] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI2_BCLK Route
[ 3.015852] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
-> [DAC_MOD_CLK] -> ASI2_BCLK Route)
[ 3.028842] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI2_BCLK Ro
ute
[ 3.038963] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI2_BCLK Ro
ute
[ 3.049085] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
DC_CLK] -> ASI2_BCLK Route)
[ 3.061290] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI2_BCLK Route
[ 3.070629] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI2_BCLK Route
[ 3.079969] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
-> [ADC_MOD_CLK] -> ASI2_BCLK Route)
[ 3.092956] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI2_BCLK Ro
ute
[ 3.103078] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI2_BCLK Ro
ute
[ 3.113216] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
AC_CLK] -> ASI3_BCLK Route)
[ 3.125427] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI3_BCLK Route
[ 3.134767] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI3_BCLK Route
[ 3.144113] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
-> [DAC_MOD_CLK] -> ASI3_BCLK Route)
[ 3.157103] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI3_BCLK Ro
ute
[ 3.167226] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI3_BCLK Ro
ute
[ 3.177349] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
DC_CLK] -> ASI3_BCLK Route)
[ 3.189556] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI3_BCLK Route
[ 3.198895] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI3_BCLK Route
[ 3.208234] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
-> [ADC_MOD_CLK] -> ASI3_BCLK Route)
[ 3.221223] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI3_BCLK Ro
ute
[ 3.231345] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI3_BCLK Ro
ute
[ 3.241476] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI1
_BCLK Route -> ASI1_BCLK)
[ 3.253510] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI1_BCLK Route --> (null) --> ASI1_BCLK
[ 3.263024] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI1_BCLK Route -> direct -> ASI1_BCLK
[ 3.272543] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI2
_BCLK Route -> ASI2_BCLK)
[ 3.284577] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI2_BCLK Route --> (null) --> ASI2_BCLK
[ 3.294090] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI2_BCLK Route -> direct -> ASI2_BCLK
[ 3.303610] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI3
_BCLK Route -> ASI3_BCLK)
[ 3.315644] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI3_BCLK Route --> (null) --> ASI3_BCLK
[ 3.325158] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI3_BCLK Route -> direct -> ASI3_BCLK
[ 3.334712] aic3262_codec_read enter
[ 3.334926] tlv320aic3262-codec 2-0018: Firmware binary load
[ 3.344256] Entering crc 7489
[ 3.344557] CRC pass
[ 3.347548] Loaded firmware inside unpickle
[ 3.353963] Unable to handle kernel paging request at virtual address ffffffe049b02a31
[ 3.361916] Oops [#1]
[ 3.364202] Modules linked in:
[ 3.367276] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 5.10.41-nb2+ #1193
[ 3.374189] Workqueue: events request_firmware_work_func
[ 3.379519] epc: ffffffe00066165a ra : ffffffe00066161e sp : ffffffe0028abd60
[ 3.386670] gp : ffffffe0024bea28 tp : ffffffe002891080 t0 : ffffffe002414f70
[ 3.393917] t1 : ffffffe00044419a t2 : 00000000000016ad s0 : ffffffe0028abd90
[ 3.401163] s1 : ffffffe001ef5800 a0 : 000000000000001f a1 : ffffffe0024812f0
[ 3.408409] a2 : 0000000000000058 a3 : ffffffe049b029f1 a4 : ffffffe001ef5801
[ 3.415654] a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 000000000000002e
[ 3.422900] s2 : ffffffe007a37ac0 s3 : 0000000000000001 s4 : ffffffffc0a7c5f8
[ 3.430145] s5 : ffffffe00240efe8 s6 : 0000000000000000 s7 : ffffffe00240f050
[ 3.437390] s8 : 0000000000000001 s9 : 0000000000000402 s10: ffffffffffffffff
[ 3.444637] s11: ffffffe002832240 t3 : 8068454649079b00 t4 : ffffffe002200328
[ 3.451882] t5 : ffffffe00240f5d8 t6 : ffffffe0028abac8
[ 3.457208] status: 0000000200000120 badaddr: ffffffe049b02a31 cause: 000000000000000d
[ 3.465163] ---[ end trace 2999eb325d73b790 ]---
[ 3.469892] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[ 3.475164] aic3262_codec_read exit
[ 3.475191] aic3262_codec_read enter
[ 3.479106] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[ 3.487959] aic3262_codec_read exit
[ 3.487974] aic3262_codec_read enter
[ 3.491883] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
[ 3.500817] aic3262_codec_read exit
[ 3.500825] aic3262_codec_read enter
[ 3.504732] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
[ 3.513664] aic3262_codec_read exit
[ 3.513672] aic3262_codec_read enter
[ 3.517578] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[ 3.526422] aic3262_codec_read exit
[ 3.526429] aic3262_codec_read enter
[ 3.530335] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[ 3.539181] aic3262_codec_read exit
[ 3.539194] aic3262_codec_read enter
[ 3.543094] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[ 3.551939] aic3262_codec_read exit
[ 3.551961] aic3262_codec_read enter
[ 3.555868] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[ 3.564720] aic3262_codec_read exit
[ 3.564731] aic3262_codec_read enter
[ 3.568639] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[ 3.577482] aic3262_codec_read exit
[ 3.577489] aic3262_codec_read enter
[ 3.581394] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[ 3.590239] aic3262_codec_read exit
[ 3.590246] aic3262_codec_read enter
[ 3.594150] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[ 3.602999] aic3262_codec_read exit
[ 3.603012] aic3262_codec_read enter
[ 3.606919] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[ 3.615764] aic3262_codec_read exit
[ 3.615772] aic3262_codec_read enter
[ 3.619678] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[ 3.628523] aic3262_codec_read exit
[ 3.628535] aic3262_codec_read enter
[ 3.632445] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[ 3.641291] aic3262_codec_read exit
[ 3.641303] aic3262_codec_read enter
[ 3.645211] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[ 3.654056] aic3262_codec_read exit
[ 3.654089] aic3262_codec_read enter
[ 3.658002] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
[ 3.666934] aic3262_codec_read exit
[ 3.666947] aic3262_codec_read enter
[ 3.670854] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
[ 3.679788] aic3262_codec_read exit
[ 3.679800] aic3262_codec_read enter
[ 3.683708] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
[ 3.692640] aic3262_codec_read exit
[ 3.692652] aic3262_codec_read enter
[ 3.696561] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
[ 3.705496] aic3262_codec_read exit
[ 3.705515] aic3262_codec_read enter
[ 3.709422] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
[ 3.718268] aic3262_codec_read exit
[ 3.718279] aic3262_codec_read enter
[ 3.722187] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
[ 3.731120] aic3262_codec_read exit
[ 3.731128] aic3262_codec_read enter
[ 3.735033] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
[ 3.743878] aic3262_codec_read exit
[ 3.743890] aic3262_codec_read enter
[ 3.747796] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
[ 3.756727] aic3262_codec_read exit
[ 3.756739] aic3262_codec_read enter
[ 3.760648] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
[ 3.769495] aic3262_codec_read exit
[ 3.769533] aic3262_codec_read enter
[ 3.773737] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[ 3.782586] aic3262_codec_read exit
[ 3.782594] aic3262_codec_read enter
[ 3.786499] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[ 3.795344] aic3262_codec_read exit
[ 3.795353] aic3262_codec_read enter
[ 3.799252] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[ 3.808091] aic3262_codec_read exit
[ 3.808098] aic3262_codec_read enter
[ 3.812004] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[ 3.820846] aic3262_codec_read exit
[ 3.820853] aic3262_codec_read enter
[ 3.824757] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[ 3.833601] aic3262_codec_read exit
[ 3.833608] aic3262_codec_read enter
[ 3.837512] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[ 3.846365] aic3262_codec_read exit
[ 3.846382] aic3262_codec_read enter
[ 3.850295] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[ 3.859144] aic3262_codec_read exit
[ 3.859152] aic3262_codec_read enter
[ 3.863057] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[ 3.871899] aic3262_codec_read exit
[ 3.871908] aic3262_codec_read enter
[ 3.875813] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[ 3.884658] aic3262_codec_read exit
[ 3.884666] aic3262_codec_read enter
[ 3.888570] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[ 3.897416] aic3262_codec_read exit
[ 3.897423] aic3262_codec_read enter
[ 3.901328] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[ 3.910175] aic3262_codec_read exit
[ 3.910182] aic3262_codec_read enter
[ 3.914086] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[ 3.922931] aic3262_codec_read exit
[ 3.922939] aic3262_codec_read enter
[ 3.926842] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[ 3.935686] aic3262_codec_read exit
[ 3.935693] aic3262_codec_read enter
[ 3.939597] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[ 3.948441] aic3262_codec_read exit
[ 3.948449] aic3262_codec_read enter
[ 3.952354] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[ 3.961198] aic3262_codec_read exit
[ 3.961205] aic3262_codec_read enter
[ 3.965110] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[ 3.973956] aic3262_codec_read exit
[ 3.973964] aic3262_codec_read enter
[ 3.977869] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[ 3.986705] aic3262_codec_read exit
[ 3.986712] aic3262_codec_read enter
[ 3.990619] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[ 3.999465] aic3262_codec_read exit
[ 3.999480] aic3262_codec_read enter
[ 4.003378] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.012223] aic3262_codec_read exit
[ 4.012229] aic3262_codec_read enter
[ 4.016137] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.024983] aic3262_codec_read exit
[ 4.024989] aic3262_codec_read enter
[ 4.028892] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.037738] aic3262_codec_read exit
[ 4.037751] aic3262_codec_read enter
[ 4.041658] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.050503] aic3262_codec_read exit
[ 4.050513] aic3262_codec_read enter
[ 4.054417] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.063264] aic3262_codec_read exit
[ 4.063271] aic3262_codec_read enter
[ 4.067173] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.076014] aic3262_codec_read exit
[ 4.076020] aic3262_codec_read enter
[ 4.079925] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.088770] aic3262_codec_read exit
[ 4.088779] aic3262_codec_read enter
[ 4.092686] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.101533] aic3262_codec_read exit
[ 4.101538] aic3262_codec_read enter
[ 4.105444] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.114290] aic3262_codec_read exit
[ 4.114295] aic3262_codec_read enter
[ 4.118200] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[ 4.127046] aic3262_codec_read exit
[ 4.127054] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Le
ft DAC
[ 4.140946] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
[ 4.150722] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
[ 4.160498] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Ri
ght DAC
[ 4.170967] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
[ 4.180829] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
[ 4.190690] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Le
ft DAC
[ 4.201073] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
[ 4.210844] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
[ 4.220620] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Ri
ght DAC
[ 4.231089] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
[ 4.240950] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
[ 4.250809] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Le
ft DAC
[ 4.261190] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
[ 4.270964] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
[ 4.280739] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Ri
ght DAC
[ 4.291206] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
[ 4.301066] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
[ 4.310937] aic3262_codec_read enter
[ 4.311631] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
[ 4.320477] aic3262_codec_read exit
[ 4.320488] aic3262_codec_read enter
[ 4.324397] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
[ 4.333331] aic3262_codec_read exit
[ 4.333347] aic3262_codec_read enter
[ 4.337256] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
[ 4.346102] aic3262_codec_read exit
[ 4.346124] aic3262_codec_read enter
[ 4.350035] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
[ 4.358973] aic3262_codec_read exit
[ 4.358989] aic3262_codec_read enter
[ 4.362796] random: fast init done
[ 4.370214] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
[ 4.375380] aic3262_codec_read exit
[ 4.375388] aic3262_codec_read enter
[ 4.379289] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
[ 4.388043] aic3262_codec_read exit
[ 4.388062] aic3262_codec_read enter
[ 4.392259] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[ 4.401106] aic3262_codec_read exit
[ 4.401113] aic3262_codec_read enter
[ 4.405020] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[ 4.413865] aic3262_codec_read exit
[ 4.413873] aic3262_codec_read enter
[ 4.417778] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[ 4.426625] aic3262_codec_read exit
[ 4.426633] aic3262_codec_read enter
[ 4.430538] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
[ 4.439381] aic3262_codec_read exit
[ 4.439389] aic3262_codec_read enter
[ 4.443288] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[ 4.452129] aic3262_codec_read exit
[ 4.452136] aic3262_codec_read enter
[ 4.456041] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[ 4.464887] aic3262_codec_read exit
[ 4.464893] aic3262_codec_read enter
[ 4.468800] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[ 4.477643] aic3262_codec_read exit
[ 4.477651] aic3262_codec_read enter
[ 4.481558] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
[ 4.490402] aic3262_codec_read exit
[ 4.490414] aic3262_codec_read enter
[ 4.494322] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[ 4.503166] aic3262_codec_read exit
[ 4.503176] aic3262_codec_read enter
[ 4.507075] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[ 4.515920] aic3262_codec_read exit
[ 4.515934] aic3262_codec_read enter
[ 4.519843] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[ 4.528690] aic3262_codec_read exit
[ 4.528697] aic3262_codec_read enter
[ 4.532603] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[ 4.541452] aic3262_codec_read exit
[ 4.541457] aic3262_codec_read enter
[ 4.545365] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[ 4.554210] aic3262_codec_read exit
[ 4.554217] aic3262_codec_read enter
[ 4.558124] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
[ 4.566970] aic3262_codec_read exit
[ 4.566983] aic3262_codec_read enter
[ 4.570891] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[ 4.579738] aic3262_codec_read exit
[ 4.579749] aic3262_codec_read enter
[ 4.583659] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[ 4.592509] aic3262_codec_read exit
[ 4.592519] aic3262_codec_read enter
[ 4.596428] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[ 4.605274] aic3262_codec_read exit
[ 4.605281] aic3262_codec_read enter
[ 4.609186] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
[ 4.618033] aic3262_codec_read exit
[ 4.618043] aic3262_codec_read enter
[ 4.621949] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[ 4.630796] aic3262_codec_read exit
[ 4.630803] aic3262_codec_read enter
[ 4.634710] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[ 4.643556] aic3262_codec_read exit
[ 4.643588] aic3262_codec_read enter
[ 4.647787] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[ 4.656635] aic3262_codec_read exit
[ 4.656649] aic3262_codec_read enter
[ 4.660559] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[ 4.669407] aic3262_codec_read exit
[ 4.669419] aic3262_codec_read enter
[ 4.673326] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[ 4.682172] aic3262_codec_read exit
[ 4.682185] aic3262_codec_read enter
[ 4.686092] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[ 4.694938] aic3262_codec_read exit
[ 4.694967] aic3262_codec_read enter
[ 4.699175] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[ 4.707929] aic3262_codec_read exit
[ 4.707938] aic3262_codec_read enter
[ 4.711849] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[ 4.720606] aic3262_codec_read exit
[ 4.720613] aic3262_codec_read enter
[ 4.724519] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[ 4.733280] aic3262_codec_read exit
[ 4.733286] aic3262_codec_read enter
[ 4.737193] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[ 4.745954] aic3262_codec_read exit
[ 4.745966] aic3262_codec_read enter
[ 4.749874] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[ 4.758721] aic3262_codec_read exit
[ 4.758731] aic3262_codec_read enter
[ 4.762636] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[ 4.771483] aic3262_codec_read exit
[ 4.771489] aic3262_codec_read enter
[ 4.775388] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[ 4.784226] aic3262_codec_read exit
[ 4.784231] aic3262_codec_read enter
[ 4.788138] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[ 4.796986] aic3262_codec_read exit
[ 4.796996] aic3262_codec_read enter
[ 4.800903] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[ 4.809747] aic3262_codec_read exit
[ 4.809759] aic3262_codec_read enter
[ 4.813665] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[ 4.822512] aic3262_codec_read exit
[ 4.822522] aic3262_codec_read enter
[ 4.826427] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[ 4.835272] aic3262_codec_read exit
[ 4.835279] aic3262_codec_read enter
[ 4.839178] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[ 4.848016] aic3262_codec_read exit
[ 4.848022] aic3262_codec_read enter
[ 4.851926] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[ 4.860772] aic3262_codec_read exit
[ 4.860783] aic3262_codec_read enter
[ 4.864686] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[ 4.873543] aic3262_codec_read exit
[ 4.873562] aic3262_codec_read enter
[ 4.877474] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[ 4.886237] aic3262_codec_read exit
[ 4.886246] aic3262_codec_read enter
[ 4.890156] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[ 4.898914] aic3262_codec_read exit
[ 4.898922] aic3262_codec_read enter
[ 4.902829] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[ 4.911587] aic3262_codec_read exit
[ 4.911603] aic3262_codec_read enter
[ 4.915504] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[ 4.924257] aic3262_codec_read exit
[ 4.924270] aic3262_codec_read enter
[ 4.928179] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[ 4.937025] aic3262_codec_read exit
[ 4.937034] aic3262_codec_read enter
[ 4.940942] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[ 4.949788] aic3262_codec_read exit
[ 4.949795] aic3262_codec_read enter
[ 4.953701] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[ 4.962547] aic3262_codec_read exit
[ 4.962553] aic3262_codec_read enter
[ 4.966459] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[ 4.975306] aic3262_codec_read exit
[ 4.975317] aic3262_codec_read enter
[ 4.979220] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[ 4.988062] aic3262_codec_read exit
[ 4.988070] aic3262_codec_read enter
[ 4.991980] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[ 5.000824] aic3262_codec_read exit
[ 5.000831] aic3262_codec_read enter
[ 5.004737] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[ 5.013584] aic3262_codec_read exit
[ 5.013590] aic3262_codec_read enter
[ 5.017497] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[ 5.026343] aic3262_codec_read exit
[ 5.026364] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
[ 5.038431] aic3262_codec_remove enter
[ 5.038437] aic3262_set_bias_level enter
[ 5.042211] tlv320aic3262-codec 2-0018: set_bias_off
[ 5.051138] aic3262_set_bias_level exit
[ 5.051148] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
[ 5.063823] Oops [#2]
[ 5.066108] Modules linked in:
[ 5.069182] CPU: 0 PID: 25 Comm: kworker/0:1 Tainted: G D 5.10.41-nb2+ #1193
[ 5.077575] Workqueue: events deferred_probe_work_func
[ 5.082732] epc: ffffffe000218d44 ra : ffffffe00066130e sp : ffffffe0029af9e0
[ 5.089883] gp : ffffffe0024bea28 tp : ffffffe0029a0840 t0 : ffffffe00241cce8
[ 5.097129] t1 : ffffffe0029af9a8 t2 : 0000000000000001 s0 : ffffffe0029afa10
[ 5.104375] s1 : ffffffe0079eb218 a0 : 0000000000000000 a1 : ffffffe0024812f0
[ 5.111621] a2 : 0000000000000003 a3 : ffffffe002481310 a4 : 8068454649079b00
[ 5.118867] a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 8068454649079b00
[ 5.126114] s2 : 0000000000000000 s3 : ffffffe0076da718 s4 : ffffffe0024bf0a8
[ 5.133360] s5 : ffffffe007a72018 s6 : ffffffe0079eb2d0 s7 : 0000000000000001
[ 5.140606] s8 : 0000000000000000 s9 : ffffffe0024a3dd0 s10: ffffffffffffffff
[ 5.147852] s11: ffffffe007a72018 t3 : 8068454649079b00 t4 : ffffffe002200328
[ 5.155098] t5 : ffffffe00023886a t6 : ffffffe0029af748
[ 5.160424] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
[ 5.168381] ---[ end trace 2999eb325d73b791 ]---
Can you please tell me what's wrong here in Kernel Driver or Please point me to correct kernel driver.
Pragnesh
