PCM5252: How to get single ended output from pcm5252?
Part Number: PCM5252
I'm going to use PCM5252, but in the single ended output mode. I read in the pdf:"The PCM5252 can also support single ended outputs, using OUTLP and OUTRP respectively. A single 470-Ω and 2.2-nF capacitor can be used on each pin in single ended mode."
does it means, I need to use only OUTLP and OUTRP pins like below:
Or should I use external diff2se converter?
best regards
Maciek
