Part Number: TAS2110
Other Parts Discussed in Thread: TAS2563, TAS2505, TAS2562, TAS2557, TAS2558
I have custom carrier board for Jetson Nano (kernel 4.9.253) with TAS2110 audio amplifier. Firstly I made test manually - play I2S sound and configure via I2C using script, so hardware is fine. I want to implement driver for this IC, so I use driver from your website: https://git.ti.com/cgit/lpaa-android-drivers/tas2505-linux-driver/. I know that it is driver for TAS2563, but I read that it is replacement for TAS2110.
I work with Nvidia support during added this driver to Kernel (https://forums.developer.nvidia.com/t/tas2557-tas2563-implement-driver-from-kernel-source/218181). They said that on Kernel side everything looks fine and probably fault is in driver source.
Can you said me if this driver will work with TAS2110 amplifier? If not, can you said what I must change or can you send other driver?
Mateusz
