Part Number: PCM4220
Hi Team,
A customer would like to know how the dynamic range is calculated.
At 192kHz the Dynamic range is specified as 112dB. What is the voltage on VCOML and VCOMR and what is the RMS noise?
In the past, the customer used this formula: Dynamic Range = 20*Log(Vref-RMS/Noise-RMS) dB
Assuming the reference voltage is 4V then is the Noise-RMS = (4/sqrt2)/10^(112/20) = 7.1uVRMS
Is this correct? Can you help clarify?
Thank you.
Marvin
