Hi Team
Customer meets a issue of AIC3204. the signal transmission will be interrupted when configure the same channel of AIC3204 rapidly rapidly and repeatedly, then a noise occurs. shown as the below picture, channel 1 is I2S signal form DSP, and channel 2 is output signal from AIC.
after expanding the picture( channel 1 is output signal, channel 2 is I2S signal in this picture), you can find output signal stops but I2S signal still presents, and after I2S stops, a noise signal appears on output.
Can you show your insight for the reason why this issue appears?
Thanks!
