TAS5805M: The distortion of TAS5805M
Part Number: TAS5805M
Other Parts Discussed in Thread: TAS5805
Hi Dear,
The distortion of THD+N (3rd and 4th harmonics) measured by power amplifier TAS5805 exceeds the standard (1%) on our device.
and the schematic design of TAS5805:
Could you help us to analyze what problems may cause this problem?
  • Hi
    thank you for you question.
    can you tell me below information to help me analysis.
    1.output power, pvdd voltage.
    2. load resistance, using spk or resistance.
    3. switching frequency
    4. modulation mode, 1spw or other mode?
    usually, the thd is also high related to the inductor performance of LC filter, have you take a try other inductor?
    thanks.
    jesse
  • Hi, Jesse
    Please refer to the following reply,thank you.
    => 5W and 12V
    =>  6Ω, using spk
    => 768K
    =>1spw
    wen gu
  • Hi Gu
    resistance is used for testing in our datasheet.
    can you take a try with resistance to confirm whether can get close result.
    thanks.
    jesse
