Part Number: PCM2704C
Hello
There are two questions about PCM2704C I'd like to figure out.
1. is C10+R9 the Zobel network for stability? is it safe the remove it?
2. is R19+C14 the High pass filter? I saw the datasheet use an 32ohm headphone for reference. I wonder if this calculation is correct 1/2πRC = 1/2π(32||10k)(100) = 49.9Hz. The result seems not good enough for the bass?
Thank you!
