TLV320AIC3104: alsa
Part Number: TLV320AIC3104
Hello, When I input the sine wave of 100mVrms signal from LINE1LP for audio recording, when I execute the command arecord -d 10 -f cd -r 48000 -t wav 001.wav after recording the audio, there is a large clutter in the audio played back. At the same time, when connected to MIC2R, the waveform output from the bypass is very beautiful, but I execute the same command to record audio after playing the audio I just recorded, the result even can not see the waveform, why?
Simple mixer control 'PCM',0
  Capabilities: pvolume
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 127
  Mono:
  Front Left: Playback 127 [100%] [0.00dB]
  Front Right: Playback 127 [100%] [0.00dB]
Simple mixer control 'Line',0
  Capabilities: pswitch
  Mono:
  Front Left: Playback [on]
  Front Right: Playback [on]
Simple mixer control 'Line DAC',0
  Limits: Playback 0 - 118
  Mono:
  Front Left: Playback 118 [100%] [0.00dB]
  Front Right: Playback 118 [100%] [0.00dB]
Simple mixer control 'Line PGA Bypass',0
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 118
  Front Left: 118 [100%] [0.00dB]
  Front Right: 118 [100%] [0.00dB]
Simple mixer control 'ADC HPF Cut-off',0
  Capabilities: enum
  Items: 'Disabled' '0.0045xFs' '0.0125xFs' '0.025xFs'
  Item0: 'Disabled'
  Item1: 'Disabled'
Simple mixer control 'AGC',0
  Mono:
  Front Left: Playback [off]
  Front Right: Playback [off]
Simple mixer control 'De-emphasis',0
  Mono:
Simple mixer control 'HP',0
  Mono:
Simple mixer control 'HP DAC',0
  Mono:
Simple mixer control 'HP PGA Bypass',0
  Limits: 0 - 118
Simple mixer control 'HPCOM',0
  Mono:
Simple mixer control 'HPCOM DAC',0
  Mono:
Simple mixer control 'HPCOM PGA Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left AGC Attack time',0
  Capabilities: enum
  Items: '8ms' '11ms' '16ms' '20ms'
  Item0: '8ms'
Simple mixer control 'Left AGC Decay time',0
  Capabilities: enum
  Items: '100ms' '200ms' '400ms' '500ms'
  Item0: '100ms'
Simple mixer control 'Left AGC Target level',0
  Capabilities: enum
  Items: '-5.5dB' '-8dB' '-10dB' '-12dB' '-14dB' '-17dB' '-20dB' '-24dB'
  Item0: '-5.5dB'
Simple mixer control 'Left DAC Mux',0
  Capabilities: enum
  Items: 'DAC_L1' 'DAC_L3' 'DAC_L2'
  Item0: 'DAC_L1'
Simple mixer control 'Left HP Mixer DACL1',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'Left HP Mixer DACR1',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Mono: Playback 118 [100%] [0.00dB] [off]
Simple mixer control 'Left HP Mixer PGAL Bypass',0
  Mono: Playback [off]
Simple mixer control 'Left HP Mixer PGAR Bypass',0
  Capabilities: volume volume-joined pswitch pswitch-joined
  Capture channels: Mono
  Limits: 0 - 118
  Mono: 118 [100%] [0.00dB] Playback [on]
Simple mixer control 'Left HPCOM Mixer DACL1',0
  Mono: Playback [on]
Simple mixer control 'Left HPCOM Mixer DACR1',0
Simple mixer control 'Left HPCOM Mixer PGAL Bypass',0
Simple mixer control 'Left HPCOM Mixer PGAR Bypass',0
  Limits: 0 - 118
  Mono: 118 [100%] [0.00dB] Playback [off]
Simple mixer control 'Left HPCOM Mux',0
  Capabilities: enum
  Items: 'differential of HPLOUT' 'constant VCM' 'single-ended'
  Item0: 'single-ended'
Simple mixer control 'Left Line Mixer DACL1',0
Simple mixer control 'Left Line Mixer DACR1',0
  Mono: Playback 118 [100%] [0.00dB] [on]
Simple mixer control 'Left Line Mixer PGAL Bypass',0
Simple mixer control 'Left Line Mixer PGAR Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left Line1L Mux',0
  Capabilities: enum
  Items: 'single-ended' 'differential'
Simple mixer control 'Left Line1R Mux',0
  Capabilities: enum
Simple mixer control 'Left PGA Mixer Line1L',0
  Mono: Playback [on]
Simple mixer control 'Left PGA Mixer Line1R',0
Simple mixer control 'Left PGA Mixer Mic2L',0
  Mono: Playback [on]
Simple mixer control 'Left PGA Mixer Mic2R',0
Simple mixer control 'Output Driver Power-On time',0
  Capabilities: enum
  Items: '0us' '10us' '100us' '1ms' '10ms' '50ms' '100ms' '200ms' '400ms' '800ms' '2s' '4s'
  Item0: '0us'
Simple mixer control 'Output Driver Ramp-up step',0
  Capabilities: enum
  Items: '0ms' '1ms' '2ms' '4ms'
  Item0: '0ms'
Simple mixer control 'PGA',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 119
  Front Left: Capture 0 [0%] [0.00dB] [on]
  Front Right: Capture 0 [0%] [0.00dB] [on]
Simple mixer control 'Right AGC Attack time',0
  Capabilities: enum
  Item0: '8ms'
Simple mixer control 'Right AGC Decay time',0
  Capabilities: enum
  Item0: '100ms'
Simple mixer control 'Right AGC Target level',0
  Capabilities: enum
  Item0: '-5.5dB'
Simple mixer control 'Right DAC Mux',0
  Capabilities: enum
  Items: 'DAC_R1' 'DAC_R3' 'DAC_R2'
  Item0: 'DAC_R1'
Simple mixer control 'Right HP Mixer DACL1',0
Simple mixer control 'Right HP Mixer DACR1',0
Simple mixer control 'Right HP Mixer PGAL Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right HP Mixer PGAR Bypass',0
Simple mixer control 'Right HPCOM Mixer DACL1',0
Simple mixer control 'Right HPCOM Mixer DACR1',0
Simple mixer control 'Right HPCOM Mixer PGAL Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right HPCOM Mixer PGAR Bypass',0
Simple mixer control 'Right HPCOM Mux',0
  Capabilities: enum
  Items: 'differential of HPROUT' 'constant VCM' 'single-ended' 'differential of HPLCOM' 'external feedback'
Simple mixer control 'Right Line Mixer DACL1',0
Simple mixer control 'Right Line Mixer DACR1',0
Simple mixer control 'Right Line Mixer PGAL Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right Line Mixer PGAR Bypass',0
Simple mixer control 'Right Line1L Mux',0
  Capabilities: enum
Simple mixer control 'Right Line1R Mux',0
  Capabilities: enum
Simple mixer control 'Right PGA Mixer Line1L',0
Simple mixer control 'Right PGA Mixer Line1R',0
Simple mixer control 'Right PGA Mixer Mic2L',0
Simple mixer control 'Right PGA Mixer Mic2R',0
  Mono: Playback [on]
I am looking forward to hearing from you.
thank you.
