TLV320AIC3106: mono_lout audio setting inquiry
Part Number: TLV320AIC3106
hello.
I have posted an inquiry using the link below, but I would like to ask if there is anything that needs to be modified in the settings.
e2e.ti.com/.../5203902
As in the title, I want a part with MONO_LOUT output.
My current settings are:
root@am62xx-evm:~# amixer -d
Simple mixer control 'PCM',0
  Capabilities: pvolume
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 127
  Mono:
  Front Left: Playback 87 [69%] [-20.00dB]
  Front Right: Playback 87 [69%] [-20.00dB]
Simple mixer control 'Line',0
  Capabilities: pvolume pswitch
  Limits: Playback 0 - 9
  Mono:
  Front Left: Playback 0 [0%] [0.00dB] [on]
  Front Right: Playback 0 [0%] [0.00dB] [on]
Simple mixer control 'Line DAC',0
  Limits: Playback 0 - 118
  Mono:
  Front Left: Playback 71 [60%] [-23.50dB]
  Front Right: Playback 71 [60%] [-23.50dB]
Simple mixer control 'Line Line2 Bypass',0
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 118
  Front Left: 71 [60%] [-23.50dB]
  Front Right: 71 [60%] [-23.50dB]
Simple mixer control 'Line PGA Bypass',0
  Limits: 0 - 118
Simple mixer control 'Mono',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback 9 [100%] [9.00dB] [on]
Simple mixer control 'Mono DAC',0
  Mono:
  Front Left: Playback 106 [90%] [-6.00dB]
  Front Right: Playback 106 [90%] [-6.00dB]
Simple mixer control 'Mono Line2 Bypass',0
  Limits: 0 - 118
Simple mixer control 'Mono Mixer DACL1',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'Mono Mixer DACR1',0
  Mono: Playback [on]
Simple mixer control 'Mono Mixer Line2L Bypass',0
  Mono: Playback [off]
Simple mixer control 'Mono Mixer Line2R Bypass',0
Simple mixer control 'Mono Mixer PGAL Bypass',0
Simple mixer control 'Mono Mixer PGAR Bypass',0
Simple mixer control 'Mono PGA Bypass',0
  Limits: 0 - 118
Simple mixer control 'ADC HPF Cut-off',0
  Capabilities: enum
  Items: 'Disabled' '0.0045xFs' '0.0125xFs' '0.025xFs'
  Item0: 'Disabled'
  Item1: 'Disabled'
Simple mixer control 'AGC',0
  Mono:
  Front Left: Playback [off]
  Front Right: Playback [off]
Simple mixer control 'De-emphasis',0
  Mono:
Simple mixer control 'HP',0
  Mono:
Simple mixer control 'HP DAC',0
  Mono:
Simple mixer control 'HP Line2 Bypass',0
  Limits: 0 - 118
Simple mixer control 'HP PGA Bypass',0
  Limits: 0 - 118
Simple mixer control 'HPCOM',0
  Mono:
Simple mixer control 'HPCOM DAC',0
  Mono:
Simple mixer control 'HPCOM Line2 Bypass',0
  Limits: 0 - 118
Simple mixer control 'HPCOM PGA Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left AGC Attack time',0
  Capabilities: enum
  Items: '8ms' '11ms' '16ms' '20ms'
  Item0: '8ms'
Simple mixer control 'Left AGC Decay time',0
  Capabilities: enum
  Items: '100ms' '200ms' '400ms' '500ms'
  Item0: '100ms'
Simple mixer control 'Left AGC Target level',0
  Capabilities: enum
  Items: '-5.5dB' '-8dB' '-10dB' '-12dB' '-14dB' '-17dB' '-20dB' '-24dB'
  Item0: '-5.5dB'
Simple mixer control 'Left DAC Mux',0
  Capabilities: enum
  Items: 'DAC_L1' 'DAC_L3' 'DAC_L2'
  Item0: 'DAC_L1'
Simple mixer control 'Left HP Mixer DACL1',0
  Mono: Playback [on]
Simple mixer control 'Left HP Mixer DACR1',0
  Mono: Playback 118 [100%] [0.00dB] [off]
Simple mixer control 'Left HP Mixer Line2L Bypass',0
Simple mixer control 'Left HP Mixer Line2R Bypass',0
  Capabilities: volume volume-joined pswitch pswitch-joined
  Capture channels: Mono
  Limits: 0 - 118
  Mono: 118 [100%] [0.00dB] Playback [off]
Simple mixer control 'Left HP Mixer PGAL Bypass',0
Simple mixer control 'Left HP Mixer PGAR Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left HPCOM Mixer DACL1',0
  Mono: Playback [on]
Simple mixer control 'Left HPCOM Mixer DACR1',0
Simple mixer control 'Left HPCOM Mixer Line2L Bypass',0
Simple mixer control 'Left HPCOM Mixer Line2R Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left HPCOM Mixer PGAL Bypass',0
Simple mixer control 'Left HPCOM Mixer PGAR Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left HPCOM Mux',0
  Capabilities: enum
  Items: 'differential of HPLOUT' 'constant VCM' 'single-ended'
  Item0: 'differential of HPLOUT'
Simple mixer control 'Left Line Mixer DACL1',0
  Mono: Playback [on]
Simple mixer control 'Left Line Mixer DACR1',0
Simple mixer control 'Left Line Mixer Line2L Bypass',0
Simple mixer control 'Left Line Mixer Line2R Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left Line Mixer PGAL Bypass',0
Simple mixer control 'Left Line Mixer PGAR Bypass',0
  Limits: 0 - 118
Simple mixer control 'Left Line1L Mux',0
  Capabilities: enum
  Items: 'single-ended' 'differential'
  Item0: 'single-ended'
Simple mixer control 'Left Line1R Mux',0
  Capabilities: enum
Simple mixer control 'Left Line2L Mux',0
  Capabilities: enum
Simple mixer control 'Left PGA Mixer Line1L',0
  Mono: Playback [on]
Simple mixer control 'Left PGA Mixer Line1R',0
Simple mixer control 'Left PGA Mixer Line2L',0
Simple mixer control 'Left PGA Mixer Mic3L',0
Simple mixer control 'Left PGA Mixer Mic3R',0
Simple mixer control 'Output Driver Power-On time',0
  Capabilities: enum
  Items: '0us' '10us' '100us' '1ms' '10ms' '50ms' '100ms' '200ms' '400ms' '800ms' '2s' '4s'
  Item0: '0us'
Simple mixer control 'Output Driver Ramp-up step',0
  Capabilities: enum
  Items: '0ms' '1ms' '2ms' '4ms'
  Item0: '0ms'
Simple mixer control 'PGA',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 119
  Front Left: Capture 107 [90%] [53.50dB] [on]
  Front Right: Capture 107 [90%] [53.50dB] [on]
Simple mixer control 'Right AGC Attack time',0
  Capabilities: enum
  Item0: '8ms'
Simple mixer control 'Right AGC Decay time',0
  Capabilities: enum
  Item0: '100ms'
Simple mixer control 'Right AGC Target level',0
  Capabilities: enum
  Item0: '-5.5dB'
Simple mixer control 'Right DAC Mux',0
  Capabilities: enum
  Items: 'DAC_R1' 'DAC_R3' 'DAC_R2'
  Item0: 'DAC_R1'
Simple mixer control 'Right HP Mixer DACL1',0
Simple mixer control 'Right HP Mixer DACR1',0
  Mono: Playback [on]
Simple mixer control 'Right HP Mixer Line2L Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right HP Mixer Line2R Bypass',0
Simple mixer control 'Right HP Mixer PGAL Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right HP Mixer PGAR Bypass',0
Simple mixer control 'Right HPCOM Mixer DACL1',0
Simple mixer control 'Right HPCOM Mixer DACR1',0
  Mono: Playback [on]
Simple mixer control 'Right HPCOM Mixer Line2L Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right HPCOM Mixer Line2R Bypass',0
Simple mixer control 'Right HPCOM Mixer PGAL Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right HPCOM Mixer PGAR Bypass',0
Simple mixer control 'Right HPCOM Mux',0
  Capabilities: enum
  Items: 'differential of HPROUT' 'constant VCM' 'single-ended' 'differential of HPLCOM' 'external feedback'
  Item0: 'differential of HPROUT'
Simple mixer control 'Right Line Mixer DACL1',0
Simple mixer control 'Right Line Mixer DACR1',0
  Mono: Playback [on]
Simple mixer control 'Right Line Mixer Line2L Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right Line Mixer Line2R Bypass',0
Simple mixer control 'Right Line Mixer PGAL Bypass',0
  Limits: 0 - 118
Simple mixer control 'Right Line Mixer PGAR Bypass',0
Simple mixer control 'Right Line1L Mux',0
  Capabilities: enum
Simple mixer control 'Right Line1R Mux',0
  Capabilities: enum
Simple mixer control 'Right Line2R Mux',0
  Capabilities: enum
Simple mixer control 'Right PGA Mixer Line1L',0
Simple mixer control 'Right PGA Mixer Line1R',0
  Mono: Playback [on]
Simple mixer control 'Right PGA Mixer Line2R',0
Simple mixer control 'Right PGA Mixer Mic3L',0
Simple mixer control 'Right PGA Mixer Mic3R',0
root@am62xx-evm:~#
If there is anything that needs correction, please reply.
thank you
    I'm not familiar with your code structure so it's hard for me to understand your settings. But all the settings for MONO_LOP are in Register 73-79. You need to set the signal source (LINE, PGA, or DAC) power up and unmute the signal source, set the output level, power up the driver, and then unmute the driver.
    Jeff McPherson
