Hi expert,
How can we test the audio performance of PCM6260-Q1?
Can we use Audio precision to test it's SNR/THD/interchannel isolation?
Thanks!
Hi expert,
Thanks!
Yes, Audio Precision can be used to test the performance of the PCM6260-Q1.
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi,
Thanks for your reply. Can you give some guidance about the test method? I only had used AP to test audio PA products and don't know how to setup analog output and digital input to test spec like THD of PCM6260.
Jass
Hi Jass,
I will follow-up on this thread with a screenshot of the AP configuration, and describe the settings used for testing.
Thanks and Regards,
Lakshmi Narasimhan
Hi Jass,
Just fyi that the remainder of the week is a holiday in India, so Lakshmi will be able to follow up with you at the beginning of next week, if not Monday.
Jeff McPherson
Hi Jass,
the attached file contains the output/input configurations to test the PCM6260 device with APx555. Please refer to the same.
Thanks and Regards,
Lakshmi Narasimhan
