Part Number: TLV320ADC5120
Can I use TLV320ADC5120 to convert balanced audio coming out from a XLR connector?
If not can you suggest a way to do it using TI components.
Punsara.
Punsara.
Hi Punsara,
Yes, the TLV320ADC5120 accepts both microphone and line input signals, both of which are common from an XLR connector.
Typically an XLR uses pins 2 and 3 as the balanced signal. These can be used as the inputs to the TLV320ADC5120.
Jeff McPherson
