TLV320AIC3254-Q1: 20-200Hz noise issue
Part Number: TLV320AIC3254-Q1
Hi Team,
Continue this below discussion, C193 and C197 are GRM188R61E106MA73_ (0603, X5R:EIA, 10uF, DC25V),
and below is new Version PCB AP test report, the 20 to 200Hz issue was still the same
PCM1808-Q1: PCM1808-Q1 TEMPERATURE RANGE - Audio forum - Audio - TI E2E support forums
THD Ratio.pdf
/* First Play */
I2C: tlv320aic_page_select page id(0)
I2C: tlv320aic_write_reg reg_addr(00) reg_data(00)
I2C: tlv320aic_write_reg reg_addr(01) reg_data(01)  /* SW Reset (Page0/Reg1/Data:0x01)*/
I2C: tlv320aic_write_reg reg_addr(1B) reg_data(00)
I2C: tlv320aic_write_reg reg_addr(00) reg_data(00)  /* Set CLK.... */
I2C: tlv320aic_write_reg reg_addr(04) reg_data(07)
I2C: tlv320aic_write_reg reg_addr(06) reg_data(14)
I2C: tlv320aic_write_reg reg_addr(07) reg_data(00)
I2C: tlv320aic_write_reg reg_addr(08) reg_data(00)
I2C: tlv320aic_write_reg reg_addr(05) reg_data(93)
I2C: tlv320aic_write_reg reg_addr(0B) reg_data(85)
I2C: tlv320aic_write_reg reg_addr(0C) reg_data(83)
I2C: tlv320aic_write_reg reg_addr(0D) reg_data(00)
I2C: tlv320aic_write_reg reg_addr(0E) reg_data(80)
I2C: tlv320aic_page_select page id(1)
I2C: tlv320aic_write_reg reg_addr(00) reg_data(01)
I2C: tlv320aic_write_reg reg_addr(01) reg_data(08)
I2C: tlv320aic_write_reg reg_addr(02) reg_data(01)
I2C: tlv320aic_write_reg reg_addr(47) reg_data(32)
I2C: tlv320aic_write_reg reg_addr(7B) reg_data(01)
I2C: tlv320aic_write_reg reg_addr(3C) reg_data(02)  /* DAC Signal Processing Block PRB_P2 */
I2C: tlv320aic_page_select page id(44)
I2C: tlv320aic_write_reg reg_addr(00) reg_data(2C)
I2C: tlv320aic_write_reg reg_addr(01) reg_data(04)  /* Adaptive Filtering enabled for DAC */
I2C: tlv320aic_write_reg reg_addr(0E) reg_data(08)
I2C: tlv320aic_write_reg reg_addr(0F) reg_data(08)
I2C: tlv320aic_write_reg reg_addr(12) reg_data(3A)  /* LOL driver gain */
I2C: tlv320aic_write_reg reg_addr(13) reg_data(3A)
I2C: tlv320aic_write_reg reg_addr(09) reg_data(0C)  /* Power up LOL/LOR drivers */
I2C: tlv320aic_write_reg reg_addr(3F) reg_data(D4)
I2C: tlv320aic_write_reg reg_addr(40) reg_data(0C)
I2C: tlv320aic_write_reg reg_addr(41) reg_data(82)  /* Digital Volume Control */
I2C: tlv320aic_write_reg reg_addr(42) reg_data(82)
I2C: tlv320aic_write_reg reg_addr(40) reg_data(00)
I2C: tlv320aic_write_reg reg_addr(41) reg_data(E4)
I2C: tlv320aic_write_reg reg_addr(42) reg_data(E4)
