TAS5825M: Audio forum
Part Number: TAS5825M
What is the heat loss power of this chip?
  • Hi Pan,
    This will depend on your system configuration and layout. For a rough estimation, you can use the efficiency plots to determine power dissipation, then use the thermal information (section 7.4) of the datasheet to determine temperature rise. If you want idle power, you would calculate idle loss from the Iq specs in the datasheet.
    Ramsey
