Other Parts Discussed in Thread: NE5532
Hi Raymond,
We are having failures on the production line in China using the new Malaysian parts. We had not experienced any failures using the older Mexican parts with more than a years production.
These are operational failures, not performance failures. The failure rate is a few percent. I have not yet visited the factory, it is in China, to see the issue first hand.
From posts on this forum it appears that you have redesigned the part in a new silicon process to fit a fab running larger wafers. I'm afraid you have changed the device operation in the process.
We are running the parts on +/-17V rails, which should not be a problem for the NE5532 since it is rated for +/-22V operation. However, another post implies you aren't supporting anything above +/-15V. The original 5532 from Signetics was designed for the higher voltages and this has been a hallmark of the 5532 ever since.
I cannot share schematics publicly but can send them through private message.
Rich
