Part Number: TSC2004
I have a question about resetting the power supply.
1. When the power-off time is 300ms or less, the PINTDAV does not become High and the TSC2004 does not operate. Is this cause related to "Table 1. Recommended Power Cycle Timings "in the POR document? This problem occurs about 50% of the time.
https://www.ti.com/jp/lit/an/sbaa193/sbaa193.pdf
2. If so, is the sequence in "Table 5. Case 1: TSC2004 AD0 Pin is Connected to '0' " effective as a countermeasure to set the PINTDAV to High?
3. If so, can Step3 be omitted? It is difficult to execute Step3 due to the customer's circuit design. If possible, I would like to do "Step 1→2→4→ ..."
Nishie
