I'm planning to use the device in psuedo differential with external sensing mode, for headphone output. So far as I'm aware the only downside to doing this is the possibility for a ground-referenced device to be plugged in, which would cause a short to ground from the VCOM output.
Do the TAD/TAC5xxx chips have protections for this to prevent damage? And if so is that what the "Virtual Ground Fault" flags are for in the register map?
