Part Number: TAS3251
I have developed a board based on TAS3251. I'm trying to configure it to be I2S master (i.e. drive SCLK and LRCLK). The following is my configuration. I have only added the section between "I2S master begin" and "I2S master end". The rest is what PPC3 generated. However, the device does not generate SCLK or LRCLK. What am I missing?
{"addr":"0x00","value":"0x00", "comment":"program memory"}
{"addr":"0x7F","value":"0x00"}
{"addr":"0x02","value":"0x11", "comment":"standby request + power down request"}
{"addr":"0x01","value":"0x11", "comment":"reset module and reset register"}
{"addr":"0x00","value":"0x00"}
{"addr":"0x03","value":"0x11", "comment":"Mute left and right channels"}
{"addr":"0x2A","value":"0x00", "comment": "Zero data DAC data paths i.e. mute"}
{"addr":"0x25","value":"0x18", "comment": "Ignore MCLK Detection + Ignore Clock Halt Detection"}
// I2S master begin
{"addr":"0x09","value":"0x11", "comment": "Turn SCLK and LRCLK to output"}
{"addr":"0x0C","value":"0x00", "comment": "Reset SCLK and LRCLK dividers"}
{"addr":"0x20","value":"0x07", "comment": "MCLK divider to get SCLK"}
{"addr":"0x20","value":"0x40", "comment": "SCLK divider to get LRCLK"}
{"addr":"0x0C","value":"0x03", "comment": "Enable SCLK and LRCLK dividers"} // needed?
{"addr":" 0x1C","value":"0x1F", "comment": "DAC clock divider for 48kHz"}
// I2S master end
{"addr":"0x0D","value":"0x10", "comment": "The PLL reference clock is SCLK - ignored in auto clock mode"}
{"addr":"0x02","value":"0x00", "comment": "Enable the device"}
{"addr":"0x00","value":"0x00", "comment":"Enable sub channel / YM host buffer"}
{"addr":"0x7F","value":"0x8C"}
{"addr":"0x00","value":"0x1D", "comment":"prm_nosub"}
{"addr":"0x28","value":"0x00"}
{"addr":"0x29","value":"0x00"}
{"addr":"0x2A","value":"0x00"}
{"addr":"0x2B","value":"0x00"}
{"addr":"0x00","value":"0x00", "comment":"Sample rate update"}
{"addr":"0x02","value":"0x80", "comment": "Reset DSP"}
{"addr":"0x22","value":"0x03", "comment":"speed 03-48k 04-96k"}
