Is the DEM-DAI1690 EVM available? See link.
http://www.ti.com/lit/ug/sbau151/sbau151.pdf
if not, are there any evaluation modules for the PCM1690. I could not locate any on ti.com.
Hi Michael,
Unfortunately these EVMs are no longer available. See this E2E post: https://e2e.ti.com/support/data_converters/audio_converters/int-audio_converters/f/66/p/230974/811094.aspx .
There may be some EVMs "out there" in a field office, not being used, so I'll search to see if I can find one for you.
I was going to suggest a PCM1680, as it is very similar to the PCM1690, but no EVM for that one either; nor for the -Q1 version. Do you need the 8-channels for this application, or is it possible to use a DAC with fewer?
-Leonard
ACAT Dallas
