Other Parts Discussed in Thread: TLV320AIC3106
HI
I am using TLV320AIC3106 Low-Power Stereo Audio CODEC for the Headset connection.
I have 5 pins on audio port connector(circular connector) to connect stereo headset (with PTT).
Pin details:-
1.PTT , 2.MIC, 3.MIC-COMM, 4.HPLOUT, 5.HPROUT
will this connections work for stereo head set? or
I should use separate HPLCOM, HPRCOM dedicated for the head phone LEFT and RIGHT speakers respectively?.
I.e An Independent return path for the speakers from audio codec IC i.e HPCOMM
Right now i have connected MIC-COMM to Board Signal Ground through a DC filter, CODEC HPLCOM & HPRCOM connected to signal ground.
MIC-COMM ground is shared to speakers ground pins.
i have attached codec schematics, please verify it. let me know if any modifications required ?.
