[ LM48100-Q1 ] Malfunctioning Output
My customer has reported that the malfunctioning output from ESD test.
Before applying the ESD voltage (+/-8kV) to output pins (OUTA and OUTB), the output waveform is normal.
However, after applying the ESD voltage to OUTA and OUTB, the output from OUTA and OUTB turn to be in the same phase (synchronization), and it's no more differential signal. it means no sound.
In this state, once customer send some commands to LM48100-Q1, then LM48100-Q1 goes back to normal mode (playing back tone.) So it's assumed that the device is not damaged.
Can you explain why this happen? and how does ESD voltage affect to operational mode?
Thank you for your support in advance.
Ken
