Hi Team,
My customer met an issue with LM4890 when using a GPIO to control its shutdown pin. As it shows below, when a high output generates from GPIO, LM4890 is supposed to turn on. But there're some occasions that the register is set to high in MCU while no high signal is measured on the GPIO. Customer suspects if the shutdown pin of LM4890 causes the issue. It'll be appreciated if you can share the internal structure of shutdonw pin to me so that I can better convince customer. Thanks.
Patrick
