Part Number: LME49724
I'm used to see Rf/Rg resistors in the range of 10k for common operational amplifiers, but for the fully differential ones it seems that the usual values are much lower (the demo board uses 1k, in impedance matched configurations down to 250-500 ohm); is this simply because they have a lot of drive and lower resistances give less noise or there are other reasons? The 16k differential input impedance in the datasheet seems to indicate that higher values could ruin the whole virtual ground assumption!
In short, is there a recommended range for the resistors tied to the amplifiers?
Thanks in advance
