PCM5242: Purepath Studio can support PCM5242
Part Number: PCM5242
Other Parts Discussed in Thread: PCM5142
How develop PCM5242  Mini DSP? it can be supported by purepath studio?   but purepath studio has not PCM5242 frameworks.
  • Hi, Darren,
    The PCM5242 Is a device intended to be used with the HybridFlow processing system. That being said, the miniDSP of the PCM5242 is compatible with PCM5142 framework in PurePath Studio, but this is not the recommended operation. If you need a device with fully-supported PurePath Studio compatibility, I would recommend you to take a look to the PCM5142.
      -Diego Meléndez López
       Audio Applications Engineer
  • Thanks, Diego 。
