PCM5242: Use PUREPATH-CMBEVM to connect PCM5242
Part Number: PCM5242
Other Parts Discussed in Thread: PUREPATH-CMBEVM,
 Hi !
        I have no PCM5242EVM , but  i have a  PUREPATH-CMBEVM  ,    Can i  use  PUREPATH-CMBEVM  , and  jump 3  fly wire(SDA,SCL,GND)to  connect  a  PCM5242  board  ?   Thanks  !
  • Hi Frank,
    You can use the PUREPATH-CMBEVM's I2C control tab to send .cfg files to the PCM5242, though I do not know if the PCM5242EVM PurePath Console software will recognize the CMBEVM. At the very least you should be able to communicate with the device.
    Thanks!
    Paul
