Hi Team,
We have TAS5756MEVM+ PurePath mother board and they can operate normally. Now we are develop speaker using TAS5733L amplifer, Can we use this mother board to debug TAS5733L by I2C ?
Our mother board version is AIP006F, such as below. The way of connect such as figure 2. but the software indicate 'the hard ware is incorrect. Can you help ?
Hi Aggil,
The PPCMB should also support TAS5733L. I can't find obvious issue in your hardware connection. Are you using TAS7533L app in the PPC3 GUI? You can quite the hardware check and read/write the register in the the AMP device, does it work?
Shawn Zheng
Hi Aggile,
Please connect the I2C to the orange connector 'SDA' and 'SCL' or JP3.
Shawn Zheng
