Other Parts Discussed in Thread: TAS5634
I have very similar requirements and in the past i have successfully done this pbtl in parallel with an ST product. It worked well and the ics ran much cooler. So could you explain this crrent sharing problem you mention more carefully. Is this an issue with tiny differences between rds on in each chip? Has this been confirmed experimentally? Can anything be done to overcome this. For example could supply voltage be increased thereby lowering overall current, increasing power out before oc protection kicks in and lowering stress on the ics at a higher voltage?
Any thoughts, this configuration would be very useful
