Hi Davide,
Well the output of the DAC would be an analog output signal. So I would say for a digital amplifier no it cannot.
Robert Clifton
Hi Robert,
I would like to use the analog output from the DAC to drive a digital amplifier with analog input like TPA3116D2.
I think it is possible, but I would like to know if the output stage of the DAC can drive two devices: The High power stage of the TAS5756M and a TPA3116D2.
Davy
Hi Davy,
So you are wanting to drive a TPA3116D2 and a TAS5756M with a single TAS5756M?
Remember that you will be supplying a single-ended signal into these devices and that might affect performance. Another concern would be if the DAC is able to drive the inputs of these devices.
Robert Clifton
Hi Robert,
Yes, I would like to drive a TPA3116D2 and a TAS5756M with a single TAS5756M. I will use a single ended input signal like a typical application schematic in the datasheet.
Can you confirm all is ok?
Are able the DAC to drive the input of both these devices?
Thanks.
Davy
Hi Davide,
I'm unfortunately unable to test the TPA3116D2 at this time but the TAS5756M will be able to drive a TAS5756M.
Robert Clifton
Hi Robert,
don't worry. I will try to drive both amplifier. In case I will use an op-amp buffer.
Thanks.
Davy
