Hello OP-amp team,
We got 4pcs of customer return of LME49720 caused by pop-cone noise issue.
I mounted those devices on the test circuit which has 40dB gain (1kR and 100kR) at +/-12V power supply with shorted differential input node.
Pop-cone noise level at particular channel is about 5mVpp 10msec duration, it is not acceptable level on our customers audio equipment even this behavior is come from common bipolar transistor.
Our customer wants to know TI's pop-cone noise level specification of this low noise audio purpose OP-amp.
Mochizuki
Hi Mochizuki-san,
As you know, the popcorn noise isn't specified in LME49720 data sheet, so please refer to the following links.
LME49720: popcorn noise
https://e2e.ti.com/support/audio/f/6/t/725471
LM4562 / LME49720 low frequency noise
https://e2e.ti.com/support/audio/f/6/t/415907
Kato
Hello Kato-san,
Thank you for your prompt advice, I over looked those useful related sleds.
Hi Luis-san,
As Andy mentioned in previous sled,
>>It happens in wafer processing and it is very difficult to screen the devices with pop-corn noise within spec in testing process.
So, this time we captured 10msec duration pop-cone noise, 1sec range duration step noise is difficult to testing but this type of "short period step noise" might be inside of testing spec. Is it correct?
The other hand it says depended on bipolar wafer processing, do you see any variation on recent lot?
Mochizuki
Hi Luis-san,
Here is measurement data of 4pcs of customer returned devices at 40dB test circuit with +/-12V lab power supply.
As we can see pop-cone noise is not channel depended, it is not power supply noise related step noise.
Should we return those materials to you to confirm noise level on your final tester?
Mochizuki
