Part Number: TLV320AIC3254
Is it possible to use the miniDSP DAC processing block of the AIC3254 with the beep generator? I noticed the beep generator requires that the DAC processing block
must be PRB_P25, but I would like to take advantage of the miniDSP processing.
If it is not possible, can I switch processing blocks on the fly to only generate a beep, then switch back to using the miniDSP without causing any problems?
Thanks.
