I'm working with customer on a protection circuit application on LM4951A Vin whereby eFuse added upfront on supply end to ensure protection circuit kicks in to limit Vin to LM4951A. However I noticed that I'm experiencing bad audio quality during voltage surge and was wondering if fluctuating voltage input affects the audio performance & whether if OVLO triggered behavior on eFuse (auto-retry & latch type) compromises the audio amplifier performance?
BR,
Leo
Hi Leo,
I'm not very clear on the problem you're describing, can you add some scope shots or diagrams to better understand the application and what is the behavior you want to change?
I'm thinking the Vin limit you mention is causing the signal to clip, either from the input signal or from the power supply.
Best regards.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Ivan,
is it possible if we communicate via email for this post? I've got some information which may not be convenient to be shared publicly. Thanks.
BR,
Leo
Hi Leo,
Please reach out through direct e2e message, there we can share email address privately.
-Ivan Salazar
