Hi there, I had some questions regrading powering the TLV320DAC3101
Hi Daniel,
If you power down some of the supplies there is a chance of reverse biasing internal circuitry, causing some leakage current to flow from the powered supplies to the not powered ones.
If you need to power down some of the supplies, you must disable all internal settings of the device, ideally RESET pin should be pulled-down.
Current consumption depends more on the internal configuration, not as much on the supply voltages. Some reference is available in this document: TLV320AIC31xx and TLV320DAC31xx Power Consumption Characterization (Rev. B )
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
