Hi support.
I am working with your TAS2560EVM connected to my custom board. Power source, irq and i2c communications seem to work fine. I am using the driver provided here: https://git.ti.com/cgit/tas256xsw-android/tas2560-android-driver/ But I get the following error while trying to use tinyplay:
tinyplay sdcard/Download/piano2.wav -D 5 [ 28.109946] tas2560 3-004c: tas2560_startup [ 28.114288] tas2560 3-004c: tas2560_shutdown [ 28.122316] tas2560 3-004c: tas2560_startup [ 28.126660] tas2560 3-004c: tas2560_hw_params Playing sample: 2 ch, 48000 hz, 16 bit [ 28.133395] tas2560 3-004c: tas2560_prepare [ 28.137744] tas2560 3-004c: SND_SOC_DAPM_POST_PMU [ 28.142899] tas2560 3-004c: tas2560_mute, 0 [ 28.147131] tas2560 3-004c: tas2560_enable power up [ 28.152813] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38 [ 28.159704] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39 [ 28.166439] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02 [ 28.174097] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41 [ 28.183292] tas2560 3-004c: tas2560_i2c_load_data, mdelay = 2 [ 28.190410] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:108, len: 0x04 [ 28.199121] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:40, len: 0x04 [ 28.207775] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:44, len: 0x04 [ 28.216364] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:48, len: 0x04 [ 28.225032] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:28, len: 0x04 [ 28.233622] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:32, len: 0x04 [ 28.242328] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:36, len: 0x04 [ 28.251444] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:24, len: 0x04 [ 28.260118] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:100, len: 0x04 [ 28.269271] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:52, len: 0x04 [ 28.277974] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:56, len: 0x04 [ 28.288725] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:60, len: 0x04 [ 28.297343] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:64, len: 0x04 [ 28.305949] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:68, len: 0x04 [ 28.313767] tas2560 3-004c: tas2560_enable skip unmute [ 28.319981] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x0b [ 28.327738] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0xff [ 28.335792] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x40 [ 28.342988] tas2560 3-004c: tas2560_enable enableIRQ [ 28.348090] tas2560 3-004c: tas2560_enable enableIRQ OK [ 28.368223] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00 [ 28.376103] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38 [ 28.382990] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39 [ 28.389214] tas2560 3-004c: IRQ status : 0x0, 0x0 [ 28.394640] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42 [ 28.400902] tas2560 3-004c: PowSts B: 0x0, check again after 10ms [ 28.430356] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42 [ 28.436568] tas2560 3-004c: irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0 [ 28.444202] tas2560 3-004c: tas2560_LoadConfig power down to load config [ 28.451892] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00 [ 28.459782] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x00 [ 28.468254] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41 [ 28.495244] tas2560 3-004c: tas2560_i2c_load_data, msleep = 10 [ 28.501594] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x01 [ 28.535526] tas2560 3-004c: tas2560_i2c_load_data, msleep = 20 [ 28.541881] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x01 [ 28.550854] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:1, VAL: 0x01 [ 28.572214] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:73, VAL: 0x0c [ 28.579941] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:60, VAL: 0x33 [ 28.588069] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:80, VAL: 0x21 [ 28.595838] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:35, VAL: 0x41 [ 28.603809] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:36, VAL: 0x80 [ 28.615162] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:15, VAL: 0x01 [ 28.623041] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:16, VAL: 0x20 [ 28.631037] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:17, VAL: 0x00 [ 28.638807] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:18, VAL: 0x00 [ 28.646626] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:8, VAL: 0x01 [ 28.654340] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:13, VAL: 0x08 [ 28.662155] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:14, VAL: 0x10 [ 28.669923] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:9, VAL: 0x9b [ 28.677183] tas2560 3-004c: tas2560_set_ASI_fmt, 16385 [ 28.683774] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:24, mask: 0x3e, val=0x2 [ 28.693054] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x1c, val=0x0 [ 28.702351] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:22, VAL: 0x00 [ 28.709636] tas2560 3-004c: tas2560_set_bit_rate, 16 [ 28.716283] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x3, val=0x0 [ 28.724839] tas2560 3-004c: tas2560_LoadConfig power up [ 28.730476] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-6 [ 28.736673] tas2560 3-004c: irq_work_routine, start timer [ 33.763707] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-11 [ 33.769907] tas2560 3-004c: tas2560_LoadConfig power down to load config [ 33.776940] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-11 [ 33.783179] tas2560 3-004c: irq_work_routine, start timer [ 34.582413] tas2560 3-004c: tas2560_mute, 1 [ 34.586638] tas2560 3-004c: tas2560_enable power down [ 34.592123] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-11 [ 34.598386] tas2560 3-004c: tas2560_shutdown [ 39.787564] tas2560 3-004c: SND_SOC_DAPM_POST_PMD
I haven't created any audio cfg with your PPC3 tool, as this driver does not seem to read any configuration file. Is this the right approach?
Is the error related to the missing configuration file?
Should I use this driver instead?: https://git.ti.com/cgit/tas2557sw-android/tas2559-android-driver/
Ivonne Nieto
