Hai ,
We are working on audio Amplifier TPA3110D2 attached is the circuit i am using but I am not able to find any out from speaker,can you please let me know if there should be any change in the circuit I am using
Hi Jyothi,
The picture is from TPA3110D2 datasheet, could you please show me your SCH? So that I can find if there is any problem in it.
In addition, could you please check the voltage/waveform on the following pins? pin1(SD), pin2(FAULT), pin3(LINP), pin4(LINN), pin9(GVDD), pin11(RINN), pin12(RINP), pin18(OUTPR), pin20(OUTNR), pin23(OUTPR), pin25(OUTPL).
Best regarads,
Shawn Zheng
Hello Shawn,
Thanks for the reply ,
I have changed the circuit as per Figure 4.2 and now its working but I Observed a lot of heat generating by the IC ,
Any considerations to be taken to avoid heat issue please confirm
And In addition to that I had build the circuit on general purpose board for testing initially along with the audio lot if disturbance is included in the audio this may be due to external wirings and etc Hope this should not be appeared when we mount on actual PCB,
Please do update
Thanks & Regards
Jyothi
Hello Shawn,
Thanks for the update,
Will design the PCB as per the design rules,
Will come back to you for any further assistance,
Thanks & Regards
Jyothi
