Other Parts Discussed in Thread: CDCM7005
Hirano-san,
you probably have a valid comment here. Let me check with the product expert and get back to you. BR. Fritz
Hirano-san,
you are right, if PRECP is set to '1' the CP circuit is switched off. A 1kOhm resistor to VCC_CP and a 1kOhm to GND will force the voltage at pin CP_OUT to VCC_CP/2. This results in a constant current which charges the caps of the loopfilter. After the loopfilter caps are charge you can turn off the PRECP bit to '0' to be able to achieve a lock condition.
Julian
