Other Parts Discussed in Thread: LM5113, LMK04906
Hi all,
Samsung try to make the PWM pulse by using clock generator that received the signal from oscillator.
PWN pulse put into high side and low side of gate driver (LM5113) in Tx of wireless charging pad.
Since high side FET and low side FET shoudn't turn on at the same time, each pulse is need to have dead time.
What the frequency of pulse they want is 6.78MHz and duty cycle should be 50:50.
To prevent both pulses from operating simultaneously, the dead time will be needed between both pulses.
Could you suggest any idea?
Thank you.
Sammy Jeon.
