Part Number: LMX2595
Other Parts Discussed in Thread: USB2ANY,
Can someone with a known working LMX2595 evaluation board with TICS Pro Software v1.6.8 - I'm not sure what version of USB2ANY firmware (I assume latest) verify that the "Raw Registers->Read All Registers" works?
I ask because I had an issue with one of my boards that caused me to replace the LMX2595 chip. When I was checking the replacement worked I discovered that I cannot read back any register values I just receive a value of FFFF for every register. I initially assumed this was a problem with the repair but when I applied settings for 10Mhz and 100Mhz etc. the repaired board produced the requested output. This then led me to check if I could read back values on my other LMX2595 evaluation board and I could not. I received a value of FFFF for every register on that board too. This happens using either of my Reference Pro boards.
I seem to remember the read back feature used to work - but it may have been with a previous version.
