CDCLVP1208: Unused input to create an "output enable" pin
Part Number: CDCLVP1208
I am interested in using the CDCLVP1208 but my design requires an output enable pin. Since I only have one input, I was thinking I could connect my input clock signal to IN1 and leave IN0 floating. I would put a pulldown resistor on IN_SEL so the input mux defaults to IN0. Then, IN_SEL would effectively work as an active high output enable pin because if I put a 1 on IN_SEL, it will connect IN1 to the outputs. When IN_SEL is driven to 0, there would be no output from the device.
Would the setup I described work to effectively give me an output enable pin for this device? Do you foresee any issues with this setup?
Thank you!
Zach Kimble
