CDCE62005EVM running with LabVIEW
Other Parts Discussed in Thread: CDCE62005EVM
I am planning on integrating the CDCE62005EVM (clock generator board) to a larger system which will be
control by LabVIEW. So, I am trying to run the device through LabVIEW and in order to do it, I would need some help.
First, I connected the device to PC by USB port, however LabVIEW could't find the devices VISA address.
The GUI which TI provides work well, but with LabVIEW, PC to device communication didn't work.
Second, as I know all the work GUI does is just writing registry, but I believe there are some command codes
which is needed to run the device. Such as Power on, Writing registry, Reset etc. If it is possible,
it would be thankful if you share them.
Thank you.
