Other Parts Discussed in Thread: LMK00306
Hi Team,
Could you please allow me to clarify about the LVDS AC coupling termination method for LMK00306, which figure were changed in the LMK00306 latest datasheet ?
[Question1]
I believe LMK00306 could also use the following general AC coupling method.
Am I correct ? If there would be any problem, could you please let me know ?
[Question2]
The two examples for LVDS AC termination in the latest datasheet had 100ohm termination between the LVDS driver and AC coupling cap, please see below Figure 34. What is the advantage to do this instead of above construction ?
If LVDS Receiver has internal 100ohm termination and bias voltage, I thought it would only require AC cap.
If LVDS Receiver does not have internal termination and bias voltage, I thought above figure 3 would be good enough.
Kawai
