AMC1210: Unused pins
Part Number: AMC1210
Hi E2E
Good day.
How to properly terminate the following pins if unused?
AVDD -pin 10
IN4 - pin 8
PWMx -pins 11/12
ADx - pins21-28
Thank you for the help.
Carlo
  • Hello Carlo,
    Inputs should generally be pulled to GND through a resistor (10k or so), and outputs can be left floating. I would make sure to configure the signal generator output to be disabled in the register settings if you are not planning to use it.
    Scott
