Part Number: ADS7808
Other Parts Discussed in Thread: ADS8508
Device is rated operationally to perform at -40 degrees. However date codes older than 2009 are failing at -20 or below
Devices (Circuit card and the component) recover at room temperature and fail repeatedly at cold temperatures.
1. Is this a common problem with this specific part?
2. Was there a design or material change after 2009
3. Do you have a pin compatible replacement part (e.g. ADS5808UB) ?
4 Do you have any recommendations for mitigating the cold temperature failures?
