Part Number: DAC8771
Other Parts Discussed in Thread: AM4372
Customers report that some register values change unexpectedly.
When in voltage output mode, will some settings change because they are "Invalid"?
(Q1) After writing 0x0003 to the Configuration Buck-Boost Register, writing 0x1513 to the Configuration DAC Register changed the Configuration Buck-Boost Register to 0x021F.
→I think the voltage range is set to ±15V. Are there any problems in operation?
(Q2) After setting Select DAC Regsiter to 0x0020 (Dual power supply) or 0x0220 (single power supply), the value of DAC Channel Gain Calibration Register changed to 0x80000
* Before and after this operation, the DAC Channel Gain Calibration Register is not written.
→ I think that it switched to gain1.0. Is there any problem in operation?
(Q3) Please let me know if there are other register settings that change when setting registers other than the above two points. Please let me know if there are any points to note.
Hiroshi
