Other Parts Discussed in Thread: ADS124S08
Are the GPIO pins D0-D6 CMOS inputs?
We would like to know if there could be issues with leaving them floating, when configured as inputs, such as indeterminate states and ESD damage.
Alan
Hi Alan Islas,
I believe I already answered this question as it was asked by your colleague Noah: https://e2e.ti.com/support/data-converters-group/data-converters/f/data-converters-forum/1248378/lmp90100-channel-scan-order-doesn-t-seem-to-follow-first_ch-to-last_ch
The LMP90100 does not have internal pull-up / pull-down resistors on the GPIO pins. You should also not let these pins float. Tie each pin to some voltage level (either GND or VIO). You can also set the GPIOs as digital outputs, where they are allowed to float
Though it sounds like you may be far along in your design, I should also recommend our newer ADC in this device family, the ADS124S08. This is effectively a better device in all aspects (features, performance, power, size) compared to LMP90100. If not for this current project, I would consider this newer ADC for future designs
-Bryan
Hi Bryan, thank you very much for your answer. It was very helpful.
Will keep in mind your recommendation of the newer ADC for our next design.
-Alan
