Other Parts Discussed in Thread: ISO124, AMC1200, AMC1100
ISO100APmarkedup.pdf I am hoping you can help. I am trying to have a part tested, but the datasheet and way of testing does not seem to be on the datasheet.
It is a ISO100AP – an old Burr Brown/TI part.
Do you have any idea or would you know anyone who can help us with this.
The engineer is believing many of these parameters are guaranteed or internal. But we need clarification on the parameter list below.
(#1,2,4,5,6,7,11,13,14,16,17,18,20,21,22,25,26,27,29,30) – problem parameters
The list below was from the engineer. He cannot de-embed the parameters…
This datasheet is fraught with lack of information to complete testing. One by one, these are the issues:
Rated continuous ac peak or dcv – no pass fail criteria
Test Breakdown DC – no pass fail criteria
Leakage current – can test.
Vosi – no test circuit or conditions
Vosi, vs input power supplies – no conditions or test circuit
Voso - no test circuit or conditions
Voso, vs input power supplies – no conditions or test circuit
Common mode range – can test
Reference current soures – nominal can test
Reference current sources – vs power supplies – can test
Compliance voltage – no conditions or test circuit
Slew rate – can test
Input current range – no conditions or test circuit
Input current range without damage - – no conditions or test circuit
Output Voltage Swing – can test
Gain Initial Error – no conditions or test circuit
Non linearity – no conditions or test circuit
Input Offset Current Ios – no conditions or test circuit
Power Supplies supply current – can test
Ouput state supply current – no conditions or test circuit
Short circuit current limit – no conditions or test circuit
Input Current Range linear operation – no conditions or test circuit
Gain initial error – can test
Nonlinearity – no conditions or test circuit
Input offset current, initial offset – no conditions or test circuit
Input offset current vs power supplies – no conditions or test circuit
Power supply supply current – can measure
Output stage Supply voltage– no conditions or test circuit
Ouput Stage short circuit current limit – no conditions or test circuit
