I test my ads1299 evm using stm32MCU.
Next channel of Power on chennel, the unknown hex data(0x10000) output.
For example, Internal test signal output on 1,3,5, and power down 2,4 channel,
output the below waveform.
This is my register setting.
/****************************setup register******************************/
Device_ID=ADS1299_Read(REG_ID);
ADS1299_Write(REG_CONFIG1, 0x95); // default value= 0x96, about Data rate setting
ADS1299_Write(REG_CONFIG2, 0xC0);
ADS1299_Write(REG_CONFIG3, 0xFC); // default value= 0xE0, DRL ON= 0xFC
Spi1WriteByte(RDATAC);
/****** SQUARE WAVE TEST SIGNAL ******/
Spi1WriteByte(SDATAC);
ADS1299_Write (REG_CONFIG3, 0xE0);
ADS1299_Write (REG_CONFIG2, 0xD0);
ADS1299_Write (REG_CH1SET, 0x65);
ADS1299_Write (REG_CH2SET, 0xE5);
ADS1299_Write (REG_CH3SET, 0x65);
ADS1299_Write (REG_CH4SET, 0xE5);
ADS1299_Write (REG_CH5SET, 0x65);
ADS1299_Write (REG_CH6SET, 0xE5);
ADS1299_Write (REG_CH7SET, 0xE5);
ADS1299_Write (REG_CH8SET, 0xE5);
/************ LOFF Setting ************/
ADS1299_Write (REG_LOFF, 0x00); // Lead_off setting (comp_level,current amplitude,DC/AC)
ADS1299_Write(REG_CONFIG4, 0x02); // Lead_off comparator power ON=0x02, OFF=0x00
ADS1299_Write (REG_LOFF_SENSP, 0xFF);
ADS1299_Write (REG_LOFF_SENSN, 0xFF);
ADS1299_Write (REG_LOFF_FLIP, 0x01); // Lead_off curent direction
/************ RLD Setting ************/
ADS1299_Write (REG_RLD_SENSP, 0x06); //CH1P RLD
ADS1299_Write (REG_RLD_SENSN, 0x02); //CH1N RLD
Off the 1,2,4 channel, output the below waveform.
ADS1299_Write (REG_CH1SET, 0xE5);
Not only internal test signal but also input EEG signal.
Additionally, my square test signal show overshoot....
Is there any problem?
I attach my raw data file, Fs=500Hz.
