Part Number: ADS7251
my customer is detecting a delay at the outputs(pins 11,12) that is outside the datasheet specs of 15 nsec for TD_CKO.
The value , as you see in the file , is about 27 nsec.
The outputs are connected thru a series resistor of 55Ohms to I/O pins of ARTIX 7 Xilinx FPGA and the capacitive load is quite small.
Do you have any idea about the possible cause of this issue?
Power supply voltages are within the limits.
UmbertoADS7251.docx
